>>> Local load control notification *IS* available *IF* you tap-link the desired switch into the PLC. Just hold the switch button down for 10 seconds, then go to the PLC (The 2414) and tap-link the two by pressing its button for 3 seconds (link management will remove the need for this, but for now this method works).
You should re-download the links into HomeSeer after doing this (scan an reprogram). Polling should be disabled after this as it won't be needed any more.
Can somebody provide the specific detailed steps for linking my SwitchLincs and the PLC in this fashion? Whatever I am doing is not working.
Peter
Peter
