Have you ever seen it report 100%. It could be the 1-wire drivers not dealing with the saturation if you only observe it 0 when it should be at 100%. Similar logic could be applied to all humidity sensors so the software would treat 0 as 100.
mcsTemperature Version 6
Originally posted by Michael McSharry View PostHave you ever seen it report 100%. It could be the 1-wire drivers not dealing with the saturation if you only observe it 0 when it should be at 100%. Similar logic could be applied to all humidity sensors so the software would treat 0 as 100.Real courage is not securing your Wi-Fi network.
Seeing the following every 2-3 hours with HSPro Beta 2.4.0.31 update. Didn't see it with .27. Currently at .13 mcsTemp - will update to .14 tonight.
3/31/2010 11:06:25 PM mcsTemperature GetSpawnedImage on line 190 The system cannot find the file specified.
3/31/2010 11:07:25 PM mcsTemperature GetSpawnedImage on line 190 The system cannot find the file specified.- Pete
Pal Janos
Thanks for Michael!
By now the problem is solved. The main problem is the USB <>, port2 definition was (I think), but the 4-8 couldnt be controlled therefore.
I fully reinstalled HS, and all modules. After that MCS starts control well, temp sensors, and DS 2408 ports. All port is controlled now, and they execute command in short time.
As I see, the most important setting in MCS menu the DS9094 port settings, ( polling time, etc.) it has strong effect on proper work. Unfortunately I dont know all menupoints ideal setting, my help button doesnt work. Where can I find a good explanation of MCS (under HS) settings?
"Reporting queued error: faulting application GetWebFile.exe, version 1.0.0.0, faulting module ntdll.dll, version 5.2.3790.4455, fault address 0x0004cde2."
Removed all "getwebfile.exe" instances yesterday morning. Its still showing same in log every couple of hours. Just looked at setup:
GetWebFile is just an application that runs in a new process to execute the Windows API "URLDownloadToFile". Apparently URLDownloadToFile uses or has a relationship to ntdll.dll and I have no visibiility into what it may be. URLDownloadToFile has been part of Windows since at least W95.
To get rid of the GetSpawnedImage error then GetWebFile.exe needs to be restored for mcsTemperature or the request to download the radar images removed from mcsTemperature. Once it is restored then perhaps a better characterization of ntdll.dll fault can be determined.
Doing the above setting of the option to use INET worked. The logs are clear now.
Not an issue anymore. Yes last time I had the same issue I re-installed the GetWebFile.exe program under the mcsTemperature BIN directory and the problem went away. Easier though just to use the INET option. The 'ntdll.dll" version that is being used on my 2003WStandard is: 5.2.3790.4455 that came with 2003 SP2.
FYI - its been a couple of days with no issues.
Thanks Michael.Last edited by Pete; April 3, 2010, 12:18 PM.- Pete
New Graphing
Michael,
Will you be switching over the graphing in MCSTemperature to the same style as you introduced with newest MCSSprinklers?- Pete
No plans for that. Chart director will continue to be used. The standalone version of mcsSprinklers used a similiar display in prior years and it was based on flash. HS was not able to process the flash parameters that were used through its web server so the HS user could only use the simple HTML column charts.
I was hoping to work with the Hobby Boards 1Wire UV sensor. Unfortunately mcsTemp doesn't seem to see it on the network. Any way I might add this sensor? The doc says it uses a "custom one wire chip" but not much more other than some programming notes.Real courage is not securing your Wi-Fi network.
