I'm new with this Plug-in and got my board working using WiFi. I'm using the Arduino Beta with a WEMO D1 R1 to control a relay (as a test). The problem I have is every couple of minutes the relay toggles off and on. It seems to happen whenever the board updates. My main question is why this is happening and why does the board keep reconnecting and updating? I'm sure this is not normal. I would think that once it is connected, it would stay connected.
Relays turning on and off
You are correct that this should not happen. Where are you powering the relay from? If you power it directly from the board it might be pulling down the power enough to reset the board and the relay.
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Originally posted by enigmatheatre View PostYou are correct that this should not happen. Where are you powering the relay from? If you power it directly from the board it might be pulling down the power enough to reset the board and the relay.
Greig.
Originally posted by labbie48 View PostWell, that didn't work, relay still switching on and off. Have another brand new board, will try that one tonight.
If you capture a debug log and send it to me I might see better what is going on.
Greig.
Sent from my SM-G950F using TapatalkZwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
