Hello,
I have set up 2 ArduinoUNO boards with associated relay boards to operate ceiling fans and the sprinklers. I already have 5 NodeMCU boards, so these are boards 6 & 7. These two Arduino are non-API setups and do work as expected. However, I have set up the sprinklers in events to cycle through the various watering zones. As the event progresses, I noticed that the on/off status of the device for the particular relay does not change, and the "Last Change" time stamp does not get updated. This appears to be the case for the Arduino controlling the ceiling fans as well.
On a side note that may be related, I had to invert the output in order to actually show the relay was off. The status graphics only have one graphic range entry, and that is for "blink". I am sure that I have run into the non-changing status before and found that I have to manually add a "on" and "off" graphic. Since then I have stopped and restarted HS3 (running HS3 version 386 Linux on a Pii). It seems like the graphic definitions go away and reset back to default of blink only. At one point during some testing, I had removed all single values and graphic values except on and off. After restarting HS3, they all came back.
Has anyone else run into this?
David
David
