David,
Your plug-in is amazing. I found this thread, and site, as I'm wanting to log the temperature and humidity from my Carrier Infinity (thermostat model SYSTXCCITW01) and hoped there would be some way to do this by collecting the data sent to/from the wifi thermostat.
I have 2 of these thermostats, and can see the settings and current status on both of them cleanly in Homeseer, without much delay of updated data (temp & RH,) and can control temp set points on both stats, with little timeout or other connectivity issues others mentioned. A previous post in this thread asked if the plugin was capable of changing the mode to "fan only" and while I can't do that, I can change the mode from Cool to Heat. I also haven't had any trouble running the MyInfinity iPhone app while playing with this in HS3. Not sure if you still need them, but I'm happy to upload the plugin's enhanced logs if you want ones from functioning systems.
As said, I just found this forum and downloaded the demo version of Homeseer, so even to a complete newbie, your plugin instructions were excellent. As others here have mentioned, I am happy to pay for this, and when you mentioned you could use these funds to pay for a HS Developer License, I would argue to HS that you are bringing them business, as if this works like I need it to, I'll pay for HS3 after my 30-day demo expires!
Because I'm a newbie to Homeseer, (or perhaps because I'm an idiot as well,) I'm finding it difficult (without adding/buying another plugin) to save my temperature and humidity data to a CSV file for further analysis. I've looked through the HS3 documentation, even watched their Youtube videos, but don't see an easy way to do this. If some of the HS3 guru's here could point me to a place walking me through that, I would greatly appreciate it. Thanks in advance!
