For some reason each time i start HS i get this error:
First at startup i get this:
Then in log I see this:
I then try to disable and then enable the plugin from management, and that gives me these errors in log:
What does this mean?
Starting up....
09.11.2015 11:54:51 ~!~YR Weather Error~!~Exception in Find_Create_Devices/Find: The given key was not present in the dictionary.Startup Complete, 1 errors detected, check the log for more information.
nov-09 12:00:44 YR Weather Error Exception in Find_Create_Devices/Find: The given key was not present in the dictionary.
nov-09 12:03:47 Plug-In Finished initializing plug-in YR Weather
nov-09 12:03:47 Error Initializing plug-in(2): YR Weather Instance::Object reference not set to an instance of an object.STACK: Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
nov-09 12:03:47 YR Weather Error Exception in Find_Create_Devices/Find: The given key was not present in the dictionary.
nov-09 12:03:46 Warning Attempt by plugin to register a duplicate link of Weather Status. Plugin: YR Weather Instance:
nov-09 12:03:46 Warning Attempt by plugin to register a duplicate link of Weather Config. Plugin: YR Weather Instance:
nov-09 12:03:46 Info Plugin YR Weather has connected. IP:127.0.0.1:49669
nov-09 12:03:44 Plug-In Finished initializing plug-in YR Weather
nov-09 12:03:44 Error Initializing plug-in(2): YR Weather Instance::Object reference not set to an instance of an object.STACK: Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
nov-09 12:03:44 YR Weather Error Exception in Find_Create_Devices/Find: The given key was not present in the dictionary.
