HS2: Adding custom btns to the Vista Alarm plugin
    Raven,
    I thought i would start a new thread for this topic.
    Attached is a vb.net script. unzip it to your \scripts folder. You need to make a few changes:
    1. change the *98 code to your code
    2. Change the "1" in the SendToAlarm to the night mode sequence
    Imports HSPI_VISTAALARM
    rem this is what gets executed when you click the btn
    Sub NightMode(parms as object)
          Dim VA As Object
          VA = hs.Plugin("Vista Alarm")
          rem change 1 to the seq you need, this cmd assumes the first thing to send in the panel code, which will happen automatically, ie don't add your code
           VA.SendToAlarm("1", "Night Mode")
           VA = nothing
    End Sub
    rem this only need to be run once to add the button
    sub AddNightModeBtn(parms as object)
          rem change *98 to your device code
          hs.devicebuttonRemove ("*98", "Night Mode")
          hs.devicebuttonAdd("*98", "vistaalarmextras.vb(""NightMode"", """")", "Night Mode"+CHR(4))
    end Sub
    3. from the hs control\Immediate Script Command window, execute the following. this will add a Night Mode btn to device 98.
    hs.runex "vistaalarmextras.vb" ,"AddNightModeBtn" ,""
    You should then see the Night Mode btn.
    4. Click to test.
    One note about the placement of the new btn: the btn will not be vertically aligned like the existing btns. i will fix this in the next version of the plugin.
    Mark
    HS3 Pro 4.2.19.5
    To simulate Btn A, change
    to
    VA.SendToAlarm(chr(1), "Button A, or any text you want to show in the log")
    for Btn B use chr(2)
    for Btn C use chr(3)
    Mark
    HS3 Pro 4.2.19.5
      to
      Hi Mark,
      just to clarify, when you say change to your code
      1. the *98 code to your code
      1 = is the panel code to activate the night mode?
      2 = ? can you give an example?
        Originally posted by Raven_ View Post
        Hi Mark,
        1. *98 is the code of my "system status" device on the status page, i think yours is ]98. please verify on your status page then change the line i referenced above.
        Note: in homeseer, the housecode (ie the first character of a "code" on the status page) can be different for each installation.
        2. i think you said Btn A is your Night Mode btn, so change the line i mentioned above to
        VA.SendToAlarm(chr(1), "Night Mode")
        With debug mode on, when you hit your custom Night Mode button you will see the following in the log
        "Sending Night Mode command to the alarm"
        Mark
        HS3 Pro 4.2.19.5
          Hi Mark,
          I know this is a old sticky but I'm finally getting around to adding additional buttons to the plug-in. I followed the directions in this sticky and have successfully created a Night Mode button using the script command below.
          I'm trying to activated Keypad button "D" which is a programmed Marco in the alarm system that requires [Command] + [Code] being send to the panel. Below is what I'm using. I just can't seem get this working. Any ideas?
          Jim
          PHP Code:
          Sub NightMode
          (parms as object
          Dim VA As Object
            VA
          rem change 123 to the seq you needthis cmd assumes the first thing to send in the panel codewhich will happen automaticallyie don't add your code
            VA.SendToAlarm("D", "Night Mode")
           VA = nothing
          End Sub
            hs.devicebuttonRemove ("#98", "Night Mode")
            hs.devicebuttonAdd("#98", "vistaalarmextras.vb(""NightMode"", """")", "Night Mode"+CHR(4))
          end Sub
          Running HSPRO2 Vista Plug-in Version v1.2.15.0
            I think "D" is the problem. i think you need to replace it with
            chr(4) without quotes so the call should look like
            va.sendtoalarm(chr(4), "Night Mode") ' chr(4) is converted to btn D via the ad2usb
            Mark
            HS3 Pro 4.2.19.5
              Thanks Mark. Just tried it but no joy. How do a change the script to send the command first then send the security code.
              This is what I get with the above script line when I push the "Night Mode" button a created in device #98 of the plug-in (debugging is on).
              PHP Code:
              12/8/2013 2:32:18 PM Vista Alarm !Sending.done
              12
              /8/2013 2:32:18 PM Vista Alarm Sending [code]+
                try
                va.sendtoalarm(chr(4)+chr(4)+chr(4), "Night Mode") '
                I recall Sean changed this in some ad2usb fw that the cmd must be repeated three times.
                to send security code with the cmd do the following
                va.sendtoalarm(chr(4)+chr(4)+chr(4), "Night Mode", "1234") ' where 1234 is your code
                Mark
                HS3 Pro 4.2.19.5
                  try
                  Thanks Mark!!!! It works perfectly.
                  I used the following commands:
                  and then had to send a second separate command to make it work
                  va.sendtoalarm("1234") ' where 1234 is my panel code.
                  See code below; hope its helpful to others who are trying to activate a alarm panel macro from Keypad buttons A,B, C or D.
                  Thanks again Mark
                  Jim
                  PHP Code:
                  Sub NightMode
                  (parms as object
                  Dim VA As Object
                    VA
                  VA nothing
                  End Sub
                  sub AddNightModeBtn
                  (parms as object)
                  hs.devicebuttonRemove ("#98""Night Mode")
                  hs.devicebuttonAdd("#98""vistaalarmextras.vb(""NightMode"", """")""Night Mode"+CHR(4))
                  end Sub
                    Well that was easy. Take care.
                    I'm knee deep in porting this plugin to HS3...trying to get something posted this month, ugh!
                    Mark
                    HS3 Pro 4.2.19.5
                      I'm knee deep in porting this plug-in to HS3...trying to get something posted this month, ugh!
                      I can only imagine how much work that is. I'll be moving over to HS3 next month so hopefully I can get things up and running to help test your plug-in.
                      Again thanks and Have a Merry Christmas.
                      Jim
