iTunes DAAP plugin is designed to allow HomeSeer to control iTunes using the DAAP, DMAP and DACP protocols.
It's capable of controlling any instance of iTunes running on your local network, or any instance of a DAAP server, as forked-daapd for example.
Please report any bug.
Please read the User Guide for detailed description
Installation:
Changes to v3.0.0.33
- Added "Clear queue" action
Changes to v3.0.0.32
- Added "Add to Queue" option for "Play Album" and "Play Artist" actions
- Updated device status icons
- Fixed closing of plugin
Changes to v3.0.0.30
- Fixed problem with artists names containing special characters in the player.
Changes to v3.0.0.29
- Fixed discovery and pairing service with Avahi on Linux
- Fixed automatic login when iTunes is discovered
Changes to v3.0.0.28
- Fix speaker volume updates
Changes to v3.0.0.27
- Updated screenshots for paring plugin with iTunes
Changes to v3.0.0.26
- Fixed iTunes Action showing playlist list ID instead of name
- Fixed copy of events and move of iTunes Actions
Changes to v3.0.0.25
- Added ControlUse field for controls associated to speaker devices in order to fix "toggle On/Off" action from HSTouch
Changes to v3.0.0.24
- Fixes for Media API
Changes to v3.0.0.23
- Fixed playing a track with forked-daapd
Changes to v3.0.0.22
- Added iTunes Radios in player and as an event action.
Changes to v3.0.0.21
- Added Playlist device with dropdown list.
Changes to v3.0.0.20
- Added "Forward Speak Actions to HS Speakers" setting. Set it to No only if you use the "Pause iTunes when HS is speaking" feature and you have another plugin running as a speak proxy.
Changes to v3.0.0.19:
- Fixed encoding/decoding for Play Playlist/Play Artist/Play Album/Play Radio actions
Changes to v3.0.0.18:
- Fixed Radio Genre and Radio Stream not being persistent for "Play Radio" action
- Added timeouts for most requests sent to iTunes
Changes to v3.0.0.14:
- Fixed track ID not being persistent for "Play Playlist" action
Changes to v3.0.0.13:
- Added support for iTunes Radios
- Fixed web player list boxes
Changes to v3.0.0.12:
- Fix for accessing the web player from multiple clients
- added multiple parameters to webplayer for better integration in HSTouch
Changes to v3.0.0.9:
- Added "-" and "+" buttons to the speaker devices to decrease or increase volume by 5%
Changes to v3.0.0.8:
- Automatic connection to iTunes, even when iTunes is started after the plugin.
- Possibility to suppress hs header and footer on web player page.
Changes to v3.0.0.7:
- Linux support
Changes to v3.0.0.6:
- Support for multiple instances.
Changes to v3.0.0.5:
- Fixed control of volume device from an event
Changes to v3.0.0.4:
- Added event actions "Play Playlist", "Play Artist" and "Play Album"
Changes to v3.0.0.3:
- Added option to automatically pause iTunes when HS is speaking
- Added link to the forum
Installation:
- download the zip attached to this post and save it in the HS3 application folder in /Updates3/Zips
- download the file named updater_override.txt attached to this post and save it in the HS3 application folder.
- go to the "PLUG-INS > Manage" page and click the "Update Listing" button, then click "Additional interfaces > Test Plugin" and check the iTunes DAAP line.
- click the "Download and Install" button
- enable the plugin from the "PLUG-INS > Manage" page
- delete updater_override.txt from your HS3 application folder
- Linux support
