HS2PRO Locking Up - event ran several times
    Could someone please help me out. Every once in a while HS2PRO freezes on me and becomes un-responsive. I have been trying to track down the problem. I actually caught something in the log file that I found very confusing.
    The conditions are coming from an ELK alarm panel and an Insteon light switch. If motion sensor is normal for 10 minutes and the light is on - then turn the light off. Can anyone make any sense of this? The amount of times that this was executed with any time lapse is amazing!
    5/7/2014 8:45:50 PM ~!~UltraM1G Info~!~ControlOutput() is setting output 010 from On to Off.
    5/7/2014 8:45:50 PM ~!~Event~!~Event Trigger "Front Entrance Lights - OFF"
    5/7/2014 8:45:50 PM ~!~Device Control~!~Device: Upstairs Front Entrance Ceiling Light (\22) OFF
    5/7/2014 8:45:50 PM ~!~Event~!~Event Trigger "Pantry Light OFF"
    5/7/2014 8:45:50 PM ~!~Device Control~!~Device: Upstairs Pantry Ceiling Light (\23) OFF
    5/7/2014 8:45:50 PM ~!~Event~!~Event Trigger "Downstairs Bedroom Hall Lights - OFF"
    5/7/2014 8:45:50 PM ~!~Event~!~Delayed event execution skipped, the conditions applied were not met: Auto Lights - Basement:Bedroom Hall Lights - OFF (Night)
    5/7/2014 8:45:50 PM ~!~Event~!~Event Trigger "Bedroom Hall Lights - OFF (Day)"
    5/7/2014 8:45:50 PM ~!~Device Control~!~Device: Basement Bedroom Hall Wall Lights (\3) OFF
    5/7/2014 8:45:50 PM ~!~Event~!~Event Trigger "Mud Room Pots Lights - OFF"
    5/7/2014 8:45:50 PM ~!~Device Control~!~Device: Ground Level Mud Room Ceiling Pots (\15) OFF
    5/7/2014 8:45:50 PM ~!~Event~!~Event Trigger "Downstairs Hall Pot Lights - OFF"
    5/7/2014 8:45:50 PM ~!~Device Control~!~Device: Basement Basement Main Hall Ceiling Pots - MASTER (\6) OFF
    5/7/2014 8:45:50 PM ~!~Event~!~Event Trigger "Garage Lights - OFF (Motion)"
    5/7/2014 8:45:50 PM ~!~Device Control~!~Device: Garage Ceiling Light - MASTER (\66) OFF
    5/7/2014 8:45:50 PM ~!~UltraM1G Info~!~Output 010 [HVAC] is Off
    5/7/2014 8:45:50 PM ~!~Event~!~Event Trigger "Towel Rack - OFF (8:30 PM)"
    5/7/2014 8:45:50 PM ~!~UltraM1G Info~!~ControlOutput() is setting output 009 from On to Off.
    I had to delete 1/2 of these events...post was too long.
    Needless to say...homeseer became unresponsive after this for a long time before it came back to its senses. I suspect the amount of traffic to the Insteon PLM had something to do with it.
    Let me know what you think please.
    Look for an event with this device that is repeating and disable it and then inspect it. It looks like the logic in the event may need to be revised.
      Yup; I've done this before with Homeseer using more than one event for a particular variable or sets of variables causing a "circular reference" and causing log entries similar to the above stuff.
      You might want to disable any event that utilizes or creates the variable just to see what happens.
      For example:
      Function A will show the time the sun last set based on the current date. Function B will calculate the date based on the number of times the moon has orbited the earth since the last time Function B was called. So, Function B asks Function C just how many times that is. Function C doesn't know, but can figure it out by calling Function A to get the time the sun last set.
      A circular reference represents a big problem in computing. A deadlock occurs when two or more processes are each waiting for another to release a resource. Most relational databases such as Oracle and SQL Server do not allow circular referencing because there is always a problem when deleting a row from a table having dependencies to another row from another table (foreign key) which refers to the row being deleted. From the technical documentation at Microsoft: The FOREIGN KEY constraints cannot be used to create a self-referencing or circular FOREIGN KEY constraint.
      http://en.wikipedia.org/wiki/Circular_reference
        Thanks for the response guys. Whenever I am controlling lights by motion sensors I always turn a light on only if it is off and off only if it is on. I'm not sure how else to avoid the event firing multiple times in order to turn a light on or off. I have never seen this before in my systems. This is the first time I have used an alarm system in conjunction with insteon switches. I changed the condition from at least 10 min to exactly 10 min and the light is on. I don't get into scripting at all just conditions.
        By the way. What are your thoughts on HS3? Trying to figure out if I should upgrade. You guys are like vets with homeseer...
