I am using 2.0.2041.0 and the updater has stopped working.
When I click on the updater button I get this error message:
Server Error in '/' Application. <hr color="silver" size="1" width="100%">
Object reference not set to an instance of an object.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
<table bgcolor="#ffffcc" width="100%"> <tbody> <tr> <td><code>An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.</code> </td></tr></tbody></table>
Stack Trace:
<table bgcolor="#ffffcc" width="100%"> <tbody> <tr> <td><code></code>
[NullReferenceException: Object reference not set to an instance of an object.]
System.Web.Compilation.CompilationLock..cctor() +44
[TypeInitializationException: The type initializer for 'System.Web.Compilation.CompilationLock' threw an exception.]
System.Web.Compilation.CompilationLock.GetLock(Boolean& gotLock) +0
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompi led() +111
[HttpException (0x80004005): The type initializer for 'System.Web.Compilation.CompilationLock' threw an exception.]
System.Web.Compilation.BuildManager.ReportTopLevelCompilatio nException() +58
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompi led() +523
System.Web.Compilation.BuildManager.GetGlobalAsaxTypeInterna l() +10
System.Web.HttpApplicationFactory.CompileApplication() +17
System.Web.HttpApplicationFactory.Init() +119
System.Web.HttpApplicationFactory.EnsureInited() +50
System.Web.HttpApplicationFactory.GetApplicationInstance(Htt pContext context) +70
System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequ est wr) +211
</pre></td></tr></tbody></table>
<hr color="silver" size="1" width="100%"> Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
I suspect .net, but am not sure what is happening.
Any suggestions?
Bill<!-- [NullReferenceException]: Object reference not set to an instance of an object. at System.Web.Compilation.CompilationLock..cctor() [TypeInitializationException]: The type initializer for 'System.Web.Compilation.CompilationLock' threw an exception. at System.Web.Compilation.CompilationLock.GetLock(Boolean& gotLock) at System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompi led() [HttpException]: The type initializer for 'System.Web.Compilation.CompilationLock' threw an exception. at System.Web.Compilation.BuildManager.ReportTopLevelCompilatio nException() at System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompi led() at System.Web.Compilation.BuildManager.GetGlobalAsaxTypeInterna l() at System.Web.HttpApplicationFactory.CompileApplication() at System.Web.HttpApplicationFactory.Init() at System.Web.HttpApplicationFactory.EnsureInited() at System.Web.HttpApplicationFactory.GetApplicationInstance(Htt pContext context) at System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequ est wr) -->
Source Error:
Stack Trace:
Any suggestions?
