I installed the HS3 plugin on my HS3 system. I managed to, I think, get my readers set incorrectly. I deleted all the readers using the config tool, but in the log it is showing three readers, but two are reader 0 with different nodes? Probably due to my failing to reboot between each reader configuration.
Can the readers be reprogrammed correctly?
iAutomate RFID iAutomate RFID Startup Complete.
iAutomate RFID -- Automatic Reset/Retry will occur in 1 minute --
iAutomate RFID
iAutomate RFID There are 3 readers on the network.
iAutomate RFID
iAutomate RFID Reader 1 ( ) is at Node 3 with an RSSI of 50 and a gain that is LOW
iAutomate RFID Reader 0 ( ) is at Node 1 with an RSSI of 60 and a gain that is LOW
iAutomate RFID Reader 1, Node 3 has a Receiver Gain that is LOW
iAutomate RFID Reader 0, Node 2 has a Receiver Gain that is LOW
iAutomate RFID Reader 0, Node 1 has a Receiver Gain that is LOW
iAutomate RFID Network successfully reset - please wait for network enumeration and configuration to complete.
iAutomate RFID Auto Polling was successfully DISABLED.
iAutomate RFID RESTART REQUESTED - RESETTING THE RFID NETWORK
iAutomate RFID
iAutomate RFID
