Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 Event Clinic
HS3 Event Clinic Discussions related to the creation of HS3 Automation Events
Old April 10th, 2017, 09:10 PM
Kitar Kitar is offline
Question Using Netcam with email or Pushbullet
My main query is related to deleting or replacing the currentimage.jpg file before taking a snap with Netcam. If I send snaps from 3 different cameras and one camera is off-line, Netcam sends the previous snap again. My guess is that it does not have the smarts to know a camera has a problem. It would be really nice if it generated some sort of offline image instead of showing the wrong image.
Would deleting the currentimage.jpg file help Netcam deal with an off-line camera or possibly overwriting the currentimage.jpg file with your own Offline.jpg image file at the beginning of a Snap sending event?
One other thing is the Netcam View function of the plug-in as I change cameras the larger snap to the upper right of the thumbnails shows the correct camera name but a different cameras image. I am wondering if there is some workaround that can be used to force updating of that snap.
Thanks for any ideas you might have to handle this.
Old May 7th, 2017, 01:07 PM
Bump - Anyone experience similar behaviour ?
140 view , no answers. I know Netcam is bad but someone must use it.
Old May 7th, 2017, 03:14 PM
sparkman's Avatar
sparkman sparkman is offline
My only suggestion is to try UltraNetCam instead. I made the switch a few years ago and haven't looked back.
Sent from my Phone using Tapatalk
Old May 8th, 2017, 08:43 PM
Thanks for the reply Al. The need for Netcam was supposed to be a temporary. I did try Ultra's plug in and thought it was pretty good but I had planned to purchase Blue Iris so I thought the BI plugin might be a better choice. I am hesitating until I can get a fanless hot rod PC that will reside in a structured wiring box. Might be a bit of wishful thinking.
Tags
currentimage.jpg, netcam, offline camera
Pushbullet Plugin ? +1 Malosa HS3 Plug-In Development 66 November 21st, 2016 09:36 AM
Netcam image email throwing System.OutOfMemoryException Raptor HomeSeer General Discussion Area 10 May 19th, 2016 03:33 PM
Pushbullet djmilez Script & Plug-In Library Discussion 5 December 22nd, 2014 07:02 AM
Using Netcam to Email and MMS Images on Motion Trigger jbeletti HomeSeer NetCam Plug-in 21 July 19th, 2010 10:47 AM
