I am trying to pass two integers (3 and 12) to the Arduino. I have two API Outputs set up in HS3.
1.) If I set two Global Variables to the two integers, how do I set the API Outputs to the two Globals in HS3? I tried to set the Outputs up as Dimmable to pass the 3 and 12 via Device Management but, I’m not sure that works.
2.) When I received the two integers via FromHS[0] and FromHS[1], can I just display them in the Serial Monitor with a Serial.print(FromHS[0])?
