HAI Plugin Beta v3.0.1.25
    A new version of the HAI plugin was submitted to the updater this afternoon. It may take a day or so
    before it shows up. I am no longer providing the updates here to keep things a little cleaner.
    Changes in this version:
    • Fixed - issue with triggering arm/disarm events (lakemirror)
    • Added - setting low/high setpoints for temperature/humidty sensors (dean)
    ***Backup your current installation so you can revert back if needed!!
    Note: As of HS3 v3.0.0.312, HST has removed backups of the plugin updates.
    For this reason, rolling back to previous versions is dependent on the user making a backup
    before upgrading in the updater. Always make a backup of your HS folder before installing updates.
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
    Reserved 1
      You can now set low/high setpoints for your temperature and humidity sensors. You can do this by going to the HAI Plugin page, then clicking on the Temperature/Humidity Tab.
      If your devices are enabled, you can set the setpoints directly from this page.
      Note that humidity setpoints are from 1-100%
      Temperature setpoints follow regular low/high thresholds according to the OmniTemp format.
        Thanks, Rob, I'll try it tonight.
          any connection related changes in this version or should I wait for the next one?
            Not in this version I'm afraid. Will get to it ASAP.
            Sent from my SM-G935U using Tapatalk
              Unrelating to plugin / related to HS3 updating in plugin manager noticed here that HS3 V.297 on the Zee versus HS3 Pro started to slow down and cause an extended delay to updating (all around) and saw update script time outs.
              Updated the Zee last night to V.318 of HS and updater is running much faster. I think too that updater runs when not on the updater GUI which did slow down rest of HS3 GUI some. (guesstimate). Whitelisted some of the 3rd party IPs/Websites in the PFSense IP Geo blocker plugin which also improved update manager speeds.
              I have left the HAILogger on and noticed a short IP disconnect last night when updating using PCA (two separate computers).
              Updating HS3 Pro today from V.297 to V.318. (note to self - skipped HS3 Linux updates between V.298 - V.317)
              BTW only on the Zee the static IP configuration has always been wrong. There are no IP static / DHCP network settings on HS3 Linux standard or Pro. If I change it becomes more wrong such that I do not touch it and only utilize base OS for IP static configuration (Wheezy, Jessie, Ubuntu HS3 Zee2 - ARM or Intel CPU). Maybe this is only me. I just never touch it or modify the static IP in the HS3 Zee GUI.
              [ATTACH]60867[/ATTACH]
              Auto mator
                Broken Release Notes Link
                Just an FYI -
                v3.0.1.25 not yet available when I go to the plugins page on the HomeSeer Vee S2. (I understand it may take a day or two to show up.) But more importantly the Release Info Link is broken. When I click on the Release Info link for the current v3.0.1.24 version it takes me to a non-existent DropBox page.Thanks for all your hard work!
                  Originally posted by avpman View Post
                  Just an FYI -
                  Oh thanks for finding that. I will try to get those notes in there ASAP...
                    Updated plugin last night.
                    Note that I switched back to using UPB rather than HLC.
                    3.0.1.25
                    1 - Disabled plugin
                    2 - removed all HAI devices (didn't do this last time)
                    3 - Enabled plugin
                    4 - enabled zones, units and thermostat and created new devices.
                    Testing variable status with HS3 Pro, HS2 Pro (serial) and PCA (network).
                    1 - Thermostat changed to Centigrade numbers - PCA shows Fahrenheit on thermostat.
                    Homeseer 3 Pro, HS2 Pro and PCA
                    Note this is status seen when starting plugin.
                    [ATTACH]60904[/ATTACH]
                    Thermostat temperature has changed now at ~0800c to Fahrenheit.
                    [ATTACH]60906[/ATTACH]
                    Remote temperature/humidity sensors initial and current readings have been fine.
                    2 - DCM status
                    HS3 Pro, HS2 Pro and PCA
                    [ATTACH]60905[/ATTACH]
                    3 - UPB Unit status
                    Auto mator
                      Hi Rob,
                      Thanks for this update!
                      Been testing today and found Humidity seems to be working fine. Set-point updates made through the plugin are being reflected on the panel correctly, as are updates made on the panel being shown correctly on the plugin.
                      I did however notice what I assume is a 'rounding' issue for some values when doing the same for the Temperature Sensor Set points. If I set the Low temperature set-point to 19, or 19.5, or 20, or 20.5, or 21, or 21.5, or 22 all is well and the panel correctly shows exactyly the same. However if set it to 22.5 the panel seems to round down to 22.
                      Thanks again,
                      Dean
                        "Any user except"
                        Rob
                        Upgraded to 3.0.1.25
                        Created user codes in the plugin.
                        The event "Any User Except TOM Set the System to Disarm" still works fine. The event "Any User Except TOM Set the System to Arm Day" or "Arm Away" still does not fire off.
                        Seeing that a user other than me disarmed the system accomplishes 80% of what I need with this. I still would like to see a notification (or other action) if when the system is armed.
                        Any ideas? Sorry about this.
                        Tom
                          Originally posted by lakemirror View Post
                          Rob
                          Tom
                          Yeah, that one is important to me as well. My family keeps using my code though and it screws up my testing.
                          Send me your latest logs and events screenshot.
                            There are two triggers, one sends an email if anyone other than me disarms the system, the other does the same if anyone other than me arms the system day (haven't tried any other arm states).
                            The log shows me triggering each event manually, then I disarmed the system using a different user code and then armed it using a different user code. The disarming works, the arming doesn't.
                            Anything you want me to try?
                            Tom
                              Ha ha, I eventually changed my code and didn't tell anyone. Tough love.
                              Further testing this morning shows the events don't trigger for arming other than by me, regardless of the arming level (away, day, etc)
