Hi Mkoff,
Do you know the way to trigger the Fibaro RGBW module "Rainbow" mode?
Chin
Chin
Sub Main
End Sub
Sub SetParam(ByVal parms As String)
Dim param As String() = parms.Split(",")
Dim HomeID As String = "11111EEF"
Dim NodeID As String = param(0)
Dim FunctionID As String = param(1)
Dim Value As String = param(2)
Dim ConfigResult As Integer = 0
Dim ConfigResultVal(3) As String
ConfigResultVal(0) = "Unknown"
ConfigResultVal(1) = "Success"
ConfigResultVal(2) = "Queued"
ConfigResultVal(3) = "Failed"
ConfigResult = hs.PluginFunction("Z-Wave", "", "Configuration_Set", {HomeID, Convert.ToByte(NodeID), Convert.ToByte(FunctionID), Convert.ToByte(1), Convert.ToInt32(Value)})
hs.WriteLog("Param Set", "Parameter Set " & ConfigResultVal(ConfigResult))
End Sub
Sub Main
End Sub
End Sub
