I have installed to micro switches in a ceiling fan light fixture.
1 is connected to the switches and the light itself
the other one is connected only to the fan.
when i command the fan on, the lights come on, i can turn the lights off with another command.
they do share a neutral(fan/lights only have 1 neutral wired up, i connected both 'load side' neutrals from the switch together with the 1 single from the fixture), do i need to completely take apart the fixture, and run a separate neutral? so i have 1 for the lights, and one for the fan?
or is there some other issue at work here? (bad module?)
