Jon00 DataScraper/JSON Parser Script For Homeseer 3 and Homeseer 4
    #91
    Do I need to put something in the device text1 and such. I get a blank device string.
    Utility Jon00 DataScraper Bus Alerts Today
    12:48:10 PM
    Kirk
    http://cleverhouseautomation.ca
    http://southcoastwebsitedesign.ca
      #92
      Yes, you have to assign the data to the device.
      Rather than going into the details, just copy the text below to the existing settings:
      DeviceName1=Bus Alerts Today
      DeviceText1=[0]
      I would suggest you delete the device that has already been created and then it will be recreated with the name "Bus Alertts Today"
      Jon
        #93
        That did it. Of course I had to call the array, I was just not sure how it was labled. Thaks for pointing me int he right direction. I can play with it from there and get it to do the rest. Thanks for the help.
        Kirk
          #94
          I'm trying to get rainfall for the day and the value comes out as zero. I'm able to get temp, wind and other values from the page without a problem. Here is the value I'm after:
          <precip_today_in>1.73</precip_today_in>
          Here are the values it's pulling:
          [Grab1Data]
          0=Last Updated on December 22, 10:03 AM EST
          100=60.1
          200=Calm
          300=37
          400=0.00
          And the code I'm using:
          Pattern1=(?s)observation_time>(.*?)</observation_time>
          Pattern2=(?s)<temp_f>(.*?)</temp_f>
          Pattern3=(?s)<wind_string>(.*?)</wind_string>
          Pattern4=(?s)<solar_radiation>(.*?)</solar_radiation>
          Pattern5=(?s)<precip_today_in>(.*?)</precip_today_in>
          Any suggestions?
          Here is the full url:
          http://api.wunderground.com/weathers...p?ID=KNCINDIA5
            #95
            I just tried it here with your settings and it works fine with the URL you posted. There is no solar but there is no solar in the XML file either.
            Jon
              #96
              I noticed I had the wrong URL.
              Try this one and let me know:
              http://api.wunderground.com/weathers...p?ID=KNCMINTH8
                #97
                Like you said it may be working? I just pulled up the URL and the rain is now showing zero? Don't know what is going on with the station!
                  #98
                  I've just tried it with the new URL and it is working here.
                  Do you intend to pull more than 5 metrics from this web page?
                  Jon
                    #99
                    I probably will when I get mine up and running. Just playing around for now. Another question for you. Is there a way to scale an Icon to match others on the page? I tried adding an icon on a couple of them but they are 3 times the size.
                      If you do, let me know.
                      You will have to resize the images manually to 32 X 32. There are plenty on online image resize sites if you don't have a graphics editor yourself.
                      Example: http://www.picresize.com/
                      Jon
                        Thanks, I was in the process of re-sizing them but thought I would ask. I thought I read there was a max of 100 patterns. Is there something else I need to do if I want to add more?
                          There is a maximum of 5 patterns and 100 devices.
                          To obtain more metrics, you can do something like:
                          PHP Code:
                          Pattern1=(?s)observation_time>(.*?)</observation_time>.*?<temp_f>(.*?)</temp_f>.*?<wind_string>(.*?)</wind_string
                          That said, you must select entries which are further down the page from the previous metric you are extracting.
                          Jon
                            Not quite Sure How I woudl scrape thsi one Your guidance is appreciated
                            Jon, Merry Christmas
                            Trying to scrape Status from an APC Internal Website any guidance in how I would do this is appreciated.
                            The parts I am looking for are as follows:
                            <td width="34%" class="dataName"><span id="langLastBatteryXfer">Last Battery Transfer</span>:</td> <td colspan="3">Detection of distorted input</td> </tr> <tr> <td class="dataName"><span id="langInternalTemp">Internal Temperature</span>:</td> <td colspan="3">82.9&deg;F</td> </tr> <tr> <td class="dataName"><span id="langRuntimeRemaining">Runtime Remaining</span>:</td> <td colspan="3"> 2hr 48min</td> </tr> <tr> <td class="dataSubSection"><span id="langUPSInput">UPS Input</span></td> <td width="17%">&nbsp;</td> <td colspan="2">&nbsp;</td>
                            and I have
                            modified the INI to look like
                            Sample Grab1
                            [Grab1]
                            Path=http://10.0.1.7/NMC/PeO6rBiT89MOwmw+Mzh9vQ/ulstat.htm
                            TextFile=0
                            Encoding=
                            Username=apc
                            Password=apc
                            Options=
                            UserAgent=
                            Devicemode=0
                            StripHTML=1
                            Pattern1=(?s)<td width="34%" class="dataName"><span id="langLastBatteryXfer">Last Battery Transfer</span>:</td><td colspan="3">.*?</td>(.*?)</td>
                            Pattern2=(?s)<td class="dataName"><span id="langInternalTemp">Internal Temperature</span>:</td><td colspan="3">.*?F</td>(.*?);F</td>
                            Pattern3=(?s)<td class="dataName"><span id="langRuntimeRemaining">Runtime Remaining</span>:</td><td colspan="3">.*?</td>(.*?)</td>
                            Pattern4=(?s)<td class="dataName"><span id="langInputValtage">Input Voltage</span>:</td><td colspan="2">.*?;<span id="langVAC">VAC</span></td>(.*?);<span id="langVAC">VAC</span></td>
                            Pattern5=(?s)<td class="dataName"><span id="langOutputVoltage">Output Voltage</span>:</td><td colspan="2">.*?;<span id="langVAC">VAC</span></td>(.*?);<span id="langVAC">VAC</span></td>
                            DeviceName1=Wayne Hills UPS 1 Last Alarm Reported
                            DeviceText1=
                            DeviceValue1=[0]
                            DeviceImage1=
                            Speakbutton1=1
                            TriggerString1=
                            SearchMode1=1
                            TriggerEvent1=
                            DeviceName2=UPS Operating Temperature
                            DeviceText2=
                            DeviceValue2=[0]
                            DeviceImage2=
                            Speakbutton2=1
                            TriggerString2=
                            SearchMode2=1
                            TriggerEvent2=
                            DeviceName3=UPS Battery Run Time Remaing
                            DeviceText3=
                            DeviceValue3=[0]
                            DeviceImage3=
                            Speakbutton3=1
                            TriggerString3=
                            SearchMode3=1
                            TriggerEvent3=
                            DeviceName4=UPS Utility Voltage Reading
                            DeviceText4=
                            DeviceValue4=[0]
                            DeviceImage4=
                            Speakbutton4=1
                            TriggerString4=
                            SearchMode4=1
                            TriggerEvent4=
                            DeviceName5=UPS Output Voltage Reading
                            DeviceText5=
                            DeviceValue5=[0]
                            DeviceImage5=
                            Speakbutton5=1
                            TriggerString5=
                            SearchMode5=1
                            TriggerEvent5=
                              Happy Christmas to you too!
                              I'm not quite sure what your question is?
                              For the first 5 patterns you have defined, do you see the data under [Grab1Data] in the Jon00DataScraperData.ini file?
                              Jon
                                Hi all , and merry christmass !
                                i maybe can help also ,
                                i think why it doesnt scrape is because its to long , thy this one
                                Pattern1=(?s)<td width="34%" class="dataName"><span id="langLastBatteryXfer">.*?</td>(.*?)</td>
                                Pattern2=(?s)<td class="dataName"><span id="langInternalTemp">.*?</td>(.*?);F</td>
                                Pattern3=(?s)<td class="dataName"><span id="langRuntimeRemaining">.*?</td>(.*?)</td>
                                Pattern4=(?s)<td class="dataName"><span id="langInputValtage">.*?</td>(.*?);<span id="langVAC">VAC</span></td>
                                Pattern5=(?s)<td class="dataName"><span id="langOutputVoltage">.*?</td>(.*?);<span id="langVAC">VAC</span></td>
                                HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
