Delete any previous debug log and grab me a new debug log with the volume issue and attach it zipped
New Install Question
I would like to get to the bottom of it
The ALL ON and ALL OFF work on my CAV66 - I want to know why it does not work on your CAA66
It will be the weekend likely before I can devote more time to it. I am very busy on Sunday but Saturday should work.
Did the set volume work or is it still an issue?
Attached is the file.
Quick note. Is this a Russound feature you are using or are you merely turning them all on one at time via code? I'm just more curious than anything, but if it's the former, maybe the CAA66 command is different than the CAV66 command?
To produce the log, I:
- Turned on debugging
- Disabled the plugin
- Deleted the log file
- Enabled the plugin and waited a little bit
- Clicked the "All On" button
- Waited a little bit
- Zipped up the log file for you
Originally posted by Blade View PostTry 2.0.112Attached Files
Originally posted by Blade View PostClick on Tools... Control panel
In the immediate script command window, type the following:
Code:&nhs.PluginFunction("BLRussound","","SendHexTest",new Object(){1,0,"All ON","F0 00 00 7F 00 00 71 05 02 02 00 00 F1 22 00 00 01 00 00 01"})
Edit, so the first time I ran it I included the "Let me know if it turns all ON", so I ran it again. nothing.
Note that the CAA66 does not have all the commands of the other ones. For instance it does not have Party mode. Could this be one of those commands that does not work on the CAA66?
