Hello, I've been noticing for some time now that I'm getting the following error messages when HS starts up:
7/28/2007 9:46:46 AM Info Finished initializing plug-in Maestro Core
7/28/2007 9:46:46 AM Info Initializing Plug-in: Maestro Hvac
7/28/2007 9:46:46 AM Info Finished initializing plug-in Maestro Hvac
7/28/2007 9:46:46 AM Info Initializing Plug-in: Maestro Sprinklers
7/28/2007 9:46:46 AM Info Finished initializing plug-in Maestro Sprinklers
7/28/2007 9:46:46 AM Info Initializing Plug-in: Maestro Music Module
7/28/2007 9:46:57 AM Database Item Saving Event 90s Music
7/28/2007 9:46:58 AM SaveEvents EventActions set update error System.InvalidOperationException: Dynamic SQL generation for the UpdateCommand is not supported against a SelectCommand that does not return any key column information. at System.Data.Common.DbDataAdapter.UpdatingRowStatusErrors(Row UpdatingEventArgs rowUpdatedEvent, DataRow dataRow) at System.Data.Common.DbDataAdapter.Update(DataRow[] dataRows, DataTableMapping tableMapping) at System.Data.Common.DbDataAdapter.UpdateFromDataTable(DataTab le dataTable, DataTableMapping tableMapping) at System.Data.Common.DbDataAdapter.Update(DataTable dataTable) at Scheduler.HomeSeerDB.SaveEvents(DataSet ds)
7/28/2007 9:46:58 AM Database Item Saving Event 90s Music
7/28/2007 9:46:58 AM Database Item Saving Event My Top Rated
Quite frankly, I've been unable to determine if it's an iTunes problem or a Maestro problem. I'm running the most recent versions of both plug-ins. However, I'm thinking that it most likely is iTunes, since in my iTunes event group, I have all the base events that are created when the iTunes plug-in was installed, however, the device actions are all blank.
Has anyone else run across this problem?
