First post - first time installing HS2 (trial version) and can't get it working right.
I get "Page cannot be displayed" often, but not always, when accessing installer updates and "conf" pages under setup. Took several hours to successfully get z-wave interface drivers to load (just kept retrying over and over - appears to randomly work after many tries.) Many times, almost all links (except status) just don't work. Speaker.exe also doesn't connect (but that's not a major issue for me now.)
After reading many posts here, I suspected a firewall problem. First turned off Windows Firewall and Symantic. Then totally unistalled Symantic and AVG (saw reference to issues with AVG although I had later version). No improvement. Surprised I don't see reference to this issue more often on msg board - I tried it on 3 machines - had same problem on two (including work machine with corporate version of Symantic, which I can't turn off or configure so I'm not surprised). Only got it to work on one old borrowed Win 2000 machine that I can't use long term.
Is it possible that Symantic isn't totally uninstalled and that it is still blocking HS2? Any way to figure out what might be blocking? I have same problem from local and remote connections.
Running verson 2.2.0.66 on XP. I'd appreciate any suggestions - I'd like to buy it but running out of 30 day trial time and want to make sure it works first.
I'm very impressed with quality and level of support here - hope you can help me.
