Ok, so I have a Venmar Air Exchanger which utilizes the HVAC fan to distribute the fresh air throughout the house. The HVAC fan uses about 500 watts when the fan motor is engaged.
Problem #1: When the air exchanger is active and the HVAC does not heat then my wife complains that the circulating air feels cold.
Problem #2: From a power consumption perspective, I want to run the fan motor on the HVAC unit as little as possible to conserve energy.
Solution? Anyone see a problem if I were to control the air exchanger via HS/ELK M1G such that it only activates when the HVAC heat is engaged?
I would think that it would make sense to have the air exchanger bring in fresh air only when the HVAC is heating the house. This scenario would seem the most efficient addressing both the "air feels cold" and energy efficiency aspect of running the HVAC fan only when necessary. I already have the most efficient fan that I can buy, but it is still power hungry.
Thoughts? From a pure technical perspective, I have this working... Just don't know long term effects.
