I have just added a Innovelli NZW31 dimmable switch to my HS3 running on a RPI3. The screenshots below indicate that it is not a dimmable switch. I have removed this switch from HS3 and included it into a SmartThings hub. The switch works fine in a ST hub. That is, the switch can be dimmed and brightened without any problem. How can I designate this dimmable switch as dimmable in HS3?
Dimmable switch is not defined as dimmable
Originally posted by BobS0327 View PostI have just added a Innovelli NZW31 dimmable switch to my HS3 running on a RPI3. The screenshots below indicate that it is not a dimmable switch. I have removed this switch from HS3 and included it into a SmartThings hub. The switch works fine in a ST hub. That is, the switch can be dimmed and brightened without any problem. How can I designate this dimmable switch as dimmable in HS3?
If it is a device with a central scene as well as a level child there should be a root and two child nodes like below.
The node you posted is not the dimmer, it is a central scene child. You need to look at the level control child.
