I had a z-wave network with 10 devices before adding the Schage deadbolt lock. The controller is the z-stick. I added the lock to the z-stick and then added the device from the z-stick into homeseer. The device added in, but it is not correct. The device management entry is shown in attachment node 11.jpg
The text from the "Fully optimize a network" is:
Optimizing node 11 (Z-Wave Node 11 Z-Wave Interface Sigma Door Lock Node 11)...
My Z-Wave: Instructing node # 11,Z-Wave Node 11 Z-Wave Interface Sigma Door Lock Node 11, to re-discover its neighbors using interface My Z-Wave...
My Z-Wave: Device 11, Z-Wave Node 11 Z-Wave Interface Sigma Door Lock Node 11 successfully optimized.
Done. The optimization was successful, Add Return Route encountered an error. Check the log for any additional information.
Node 11 Neighbor Status: 5 Neighbors: 1, 3, 4, 5, 8
There is a Schlage link module (lamp dimmer - RP200) in the network (Node 6), but is is not shown in the "neighbors" list for node 11 (lock).
An finally, the log entry when I ran the optimize network command
Jun-22 3:42:12 PM Z-Wave ---------------------------------------------------------------------------------------
Jun-22 3:42:11 PM Z-Wave Done. The optimization was successful, Add Return Route encountered an error. Check the log for any additional information.
Jun-22 3:42:11 PM Z-Wave Warning Delete (current) Return Routes for Z-Wave Node 11 Z-Wave Interface Sigma Door Lock Node 11 (11) failed, Add Return Route will not be attempted.
Jun-22 3:41:41 PM Z-Wave My Z-Wave: Device 11, Z-Wave Node 11 Z-Wave Interface Sigma Door Lock Node 11 successfully optimized.
Jun-22 3:41:33 PM Z-Wave My Z-Wave: Instructing node # 11,Z-Wave Node 11 Z-Wave Interface Sigma Door Lock Node 11, to re-discover its neighbors using interface My Z-Wave...
Jun-22 3:41:32 PM Z-Wave Optimizing node 11 (Z-Wave Node 11 Z-Wave Interface Sigma Door Lock Node 11)...
Jun-22 3:41:32 PM Z-Wave ---------------------------------------------------------------------------------------
What do I need to do to fix this? I do have another Schlage lamp dimmer available, but it is not currently plugged in.
