Plug-in disappeared
    Plug-in disappeared
    I just downloaded and installed the latest version of the plug-in. After I was done, the plug-in no longer appears in my plug-in list even though the log contains the download and install discourse. I tried to download from the Additional Interfaces list with the same result. Task Manager does not show HSPI_WeatherXML as a running process.
    Is it really there, but invisible? What happened?
    Mar-16 5:02:54 PM Updater Install/Update of package weatherXML was successful.
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXML.doc
    Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\scripts\weatherXML_HSPhone.vb
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLVarsPluginInt.pdf
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLPluginInt.pdf
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLValueDevices.pdf
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLDatabase.pdf
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLMiscDevices.pdf
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLSchedules.pdf
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLSpeakDevices.pdf
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLMapDevices.pdf
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLLocations.pdf
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLGeneralSettings.pdf
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLQuickStart.pdf
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\Docs\weatherXML\hstouch.zip
    Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Data\weatherXML\backup\backup.txt
    Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Data\weatherXML\weatherXML.mdb
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\Docs\weatherXML\weatherXML.doc
    Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Config\weatherXML\weatherTriggers.ini
    Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Config\weatherXML\weatherInfo.ini
    Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Config\hspi_weatherXML.ini
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\weatherXML\Linux_System.Data.SQLite.dll
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\weatherXML\Windows_System.Data.SQLite.dll
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\weatherXML\Newtonsoft.Json.dll
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\weatherXML\SQLite.Interop.dll
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_WEATHERXML.exe.config
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\up.png
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\down.png
    Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\html\images\weatherXML\maps\SunMap.png
    Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\curcond.jpg
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\SunSurf.png
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\SunSpeak.png
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\SunMap.png
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\Sun.png
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\sun.gif
    Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\atom.jpg
    Mar-16 5:02:54 PM Updater Extraction Complete.
    Mar-16 5:02:54 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\wind.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\wind\
    Mar-16 5:02:54 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\thermos.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\thermos\
    Mar-16 5:02:54 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\other.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\other\
    Mar-16 5:02:54 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\moon2.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\moon2\
    Mar-16 5:02:54 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\moon.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\moon\
    Mar-16 5:02:53 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\dewpoint.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\dewpoint\
    Mar-16 5:02:53 PM Updater Extraction Complete.
    Mar-16 5:02:53 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\barometric.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\barometric\
    Mar-16 5:02:52 PM Updater Installing package weatherXML
    Mar-16 5:02:52 PM Updater Update HSPI_WEATHERXML.exe downloaded successfully
    Mar-16 5:02:48 PM Updater Downloading update: weatherXML
    A subsequent attempt to download and install produced this in the log:
    Mar-16 5:18:09 PM Updater Error saving the downloaded file: error
    Mar-16 5:18:09 PM Updater Error downloading package :An exception occurred during a WebClient request.
      Have you cycled HS? I have seen this several times on different plugins over the last few months. Normally if I keep refreshing it will finally show up, but I also have just cycled HS and it will finally show.
      Not sure when it started, but for me it has probably been off and on for 4 months or so. I normally disable all plugins before updating now as well and that seems to make it happen much less.
      Jeff
        Originally posted by cerjzc View Post
        Have you cycled HS? . . . I also have just cycled HS and it will finally show.
        Thanks, that solved it. Just restarted HS and the plug-in magically reappeared running the latest version.
