According the the help file the Boolean 'isSpeaking can be found by using the syntax
Dim isSpeaking As Boolean = hs.PluginFunction("BLSpeech", "", "IsHomeseerSpeaking", Nothing)
This errors with the criptic message of
Running script SpeechProcessing.vb :Object of type 'System.String' cannot be converted to type 'System.Boolean'.->Does entry point Main exist in script? at System.RuntimeType.TryChangeType(Object val....
What is the correct format for this function?
