Can you please either move the "ERROR A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond" to a WARN level and/or add a NONE level for logging?
My HS log is constantly flooded with these messages... I assume because some of my dongles are powered by USB ports on the devices they're attached to and are therefore offline unless in use.
