Kodi/XBMC Plug-in - Feature Requests
Originally posted by kideon View PostIs there a way to play a specific file or playlist? Imagine the potential there...
Spud,
I just had an Idea for your xbmc plugin while playing around with XBMC gotham tonight. It has added the ability to send a movie from one instance of xbmc to another and continue from the point the video was at. what I would like to be able to do is trigger this in a HS event action so that I can use it in compination with the kinect plugin. It would be cool if watching a movie in the living room a wanting to go to bed and finish it to simply issue a voice command "send movie to master bedroom" or what ever command a user wanted and have HS and XBMC do all the leg work for you.
IS this some thing that is dooable
Cheers KenHSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Originally posted by spud View PostTitle device for tv shows is now formatted as "<TV Show Title> SXXEYY - <Episode Title>"
It would also be real nice to have the path to the file as well, but I don't know if that's possible or not from XBMC
G
Originally posted by kenrad View PostIt would be cool if watching a movie in the living room a wanting to go to bed and finish it to simply issue a voice command "send movie to master bedroom" or what ever command a user wanted and have HS and XBMC do all the leg work for you.
G
there would be so many possibilities it it were an action in the pluginHSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Cheers Ken
Originally posted by gmitch64 View PostAny way they could be broken out into individual devices? I'd like to be able to change the volume and a couple of other settings based on the show (and series), and it would be nice not to have to run a script to do the string splitting.
G
Originally posted by spud View PostThat's a cool feature indeed, I will add it as a plugin action if it's available in the XBMC API.
Continue playing on another XBMC instance sort of like the Yatse android application does. I guess it uses UPnP to do this. I've been searching for the Json command but can not find one. I will continue to search.
Side note.
Did you ever find an answer to this question?
http://forum.xbmc.org/showthread.php?tid=198924
Originally posted by Mad leal View Post
