I can't get the Caddx plugin to successfully connect to the panel. I have an NX-8E connected to homeseer at home working fine. I added a new NX-8E at my office to homeseer there and can't get it to connect. Correction... it says it is connected and correctly identified the NX8E, but it denies the master pin code.
I have sunk several hours troubleshooting and now accept that I NEED HELP.
What I have tried:
-confirm correct pincode
-used same cable from working home install, tried onboard serial and USB-serial
-confirmed 9600baud on both ends Loc 208 = 2
-serial port on NX is set to ON Loc 207 =1
-Protocol set to Binary currently Loc 209 = on
-Have tried Setting to ASCII Loc 209=off - WHICH IS IT SUPPOSED TO BE?
-Tried different combinations of Loc210 and 211 DO THESE MATTER???
-Connected to serial port with terminal and got a response
-Installed DLX900 software but couldn't figure out how to connect to panel using that
I am going to try to copy all my Location settings from the Panel at home, but hopefully someone has another idea. Hopefully the NX-8e board isn't bad.
What I have tried:
