download error
    download error
    the update will not download. I uninstalled it and tried. now its just gone... the one on your page is for HS2 only....
    I paid money for this. please advise
    All HS3 plugins are in the HS3 updater
    You need to go to Manage... Plugins and then at the bottom, expand the listing. BLSpeech will be in there
    Cheers,
    Bob
      yes.. I understand this process... and it says failed. in the logs it says server returned error
        That is strange - I just checked my site from work and it was up and running
        Do you already have BLSpeech installed and you are trying to update it?
        If so, try this:
        1. Disable BLSpeech
        2. Make sure the HSPI_BLSpeech.exe is not running (if it is, then kill the process)
        3. Try to update it now
        4. Re-enable the plugin after update
        Let me know
        Cheers,
        Bob
          If so, try this:
          1. Disable BLSpeech
          Let me know
          I did. but I removed it because I thought maybe the old installation was causing an issue. I have had that happen before.
          other updates and installs have not had any issues. this is the only one as of right now.
            Sorry you are having issues updating it. I am at a loss to explain that one right now. I will have to check it once I am home from work.
            Cheers,
            Bob
              One thing I have done before is once the plugin is disabled I have restarted HS3, then updated and then re-enabled it
              Have you tried that?
              Cheers,
              Bob
                rebooted the server
                Mar-21 05:16:02 Updater
                Error saving the downloaded file: error
                Mar-21 05:16:02
                Updater Error downloading package HSPI_BLSpeech.exe:The remote server returned an error: (404) Not Found.
                  Very odd - I just checked the package and it is there.
                  I am sorry about this - I will need to check this once I get home this afternoon. I picked the wrong day to come into the office
                  Cheers,
                  Bob
                    its all good. thanks
                      Here is the direct download to the zip file (hope I get the link right)
                      BLSpeech 2.0.66.0
                      You will need to shutdown HS3, then extract just the HSPI_BLSpeech.exe into your HS3 root folder, then restart HS3
                      That should at least get you the updated version
                      Cheers,
                      Bob
                        BLSpeech 2.0.66.0
                        when I pull up the list under manage it says version 2.0.57.0 is available...
