Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Stipus Plug-Ins > SIP Connector
SIP Connector Discussion area for the SIP Connector plug-in
Old June 9th, 2009, 04:45 PM
slayer's Avatar
slayer slayer is offline
Install Error
Hello,
Just upgraded the SIP connector to 2.48.2.3 via teh updater. I am getting an error when starting Homeseer (2.3.016)
09/06/2009 20:53:35 - Error - Initializing interface: SIP Connector->Unable to load DLL 'Stipus.SipXTapi.Core.dll': This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem. (Exception from HRESULT: 0x800736B1)
Any suggestions
LiamK
Homeseer 2.4.0.1
http://liam.kitson.com
http://www.quinweather.com
Old June 11th, 2009, 06:22 AM
stipus stipus is offline
Can you see the dll Stipus.Sipxtapi.Core.dll in your HomeSeer 2 directory ?
stipus
Old June 12th, 2009, 05:49 PM
slayer's Avatar
Yes,
Stipus.SipXTapi.Core.dll (size 1456kb) is installed in the homeseer root directory along with Stipus.SipXTapI.dll
Regs
LiamK
Old June 13th, 2009, 05:33 AM
Can you check the file version of the dll ?
hspi_sip.dll
Stipus.Sipxtapi.dll
You should also find a pcre3.dll
Old June 28th, 2009, 11:38 AM
slayer's Avatar
Hello,
Still having problem getting the plugin working.
hspi_sip.dll v2.49.2.3
Stipus.Sipxtapi.dll v2.49.2.3
Stipus.Sipxtapi.Core.dll v2.49.2.3
Pcre3.dll v6.4.2194.685
Have upgrade homeseer to 2.3.0.19 but still no luck???
Regs
LiamK
Old June 28th, 2009, 01:45 PM
Please check post #7 of this thread:
http://board.homeseer.com/showthread.php?t=136379
It looks like the VC++ runtime is the problem...
Tell me if this fixed your SIP Connector !
Best regards,
Old July 5th, 2009, 05:51 PM
slayer's Avatar
That appears to sort out the problem.
Liam
HTML code is On
