you need to install bonjour, as explained in the user guide
Kodi/XBMC Plug-in - Beta Testing
This is a sticky topic.
That is odd... I did install it...
Ok, back to the drawing board... Let me reinstall it. Sorry about that, Spud.Transitioning to HS3Pro .298 - WinXPEmbedded
Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
Originally posted by zakrzep View PostHows do I use the "Radio" channels option using the event trigger.
XBMC Action -> Player Open Media
Instance: xxx
Media Type: Channel
Channel Type: Radio
I get an error.
That being said I will try to avoid this error when no channels are found.
Guest
Hi.
I'm having connection issues with this plugin and Kodi. Sometimes it connects, and most of the time it does not.
Kodi is running on the same network with a cable connection. I get connection from the android app "Kore" (remote) when I check for connectivity issues.
The system is HomeSeer 3.0.0.297 on linux.
From the log I get this:
After system reboot:
Jan-20 11:04:50 Plug-In Finished initializing plug-in Kodi
Jan-20 11:04:50 Kodi DEBUG Connecting on tcp port 9090
Jan-20 11:04:50 Kodi INFO Resolved Service: Kodi (Odroid) - _xbmc-jsonrpc-h._tcp - 10.0.0.85 - 8080
Jan-20 11:04:50 Kodi INFO Resolved Service: Kodi (Odroid) - _xbmc-jsonrpc._tcp - 10.0.0.85 - 9090
Jan-20 11:04:50 Kodi INFO Found Service: Kodi (Odroid)
Jan-20 11:04:50 Kodi INFO Kodi version 3.0.1.0Device: Kodi (Odroid) Root to Connect (-1) by/from: CAPI Control Handler[PLAYERS]
1###name=Kodi (Odroid)
1###ipaddress=10.0.0.85
1###username=kodi
[GENERAL]
log_level=Debug
upgrade_xbmc_to_kodi_done=true
[SPEAK_PROXY]
forward_to_hs=False
enable=True
display_time=10
Originally posted by rogerbl View PostHi Spud!
Got an error message when trying to register the Kodi plugin with my license number:
No more registrations are available for this license..
I disabled the old XMBC plugin before I tried to register the new one. So what do I do now?
Regards Roger
need help. just tried to download plugin and getting this.
Jun-02 9:46:03 PM Error Warning, Cannot load EXE file (possibly missing dependencies) HSPI_Kodi.exe: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.Warning, Error details with EXE HSPI_Kodi.exe: Could not load file or assembly 'System.Core, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes' or one of its dependencies. The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)Warning, Error details with EXE HSPI_Kodi.exe: Could not load file or assembly 'System.Core, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes' or one of its dependencies. The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)Warning, Error details with EXE HSPI_Kodi.exe: Could not load file or assembly 'System.Core, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes' or one of its dependencies. The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)Warning, Error details with EXE HSPI_Kodi.exe: Could not load file or assembly 'System.Core, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes' or one of its dependencies. The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)Warning, Error details with EXE HSPI_Kodi.exe: Could not load file or assembly 'System.Core, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes' or one of its dependencies. The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)Warning, Error details with EXE HSPI_Kodi.exe: Could not load file or assembly 'System.Core, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes' or one of its dependencies. The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)Warning, Error details with EXE HSPI_Kodi.exe: Could not load file or assembly 'System.Core, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes' or one of its dependencies. The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)Warning, Error details with EXE HSPI_Kodi.exe: Could not load file or assembly 'System.Core, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes' or one of its dependencies. The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)Warning, Error details with EXE HSPI_Kodi.exe: Could not load file or assembly 'System.Core, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes' or one of its dependencies. The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)
Originally posted by csullivan2005 View Postneed help. just tried to download plugin and getting this.
https://www.microsoft.com/en-us/down...s.aspx?id=3556
Thanks I got it working. Is it possible to use Alexa to speak text when searching for a movie using the the send text function. Anything like this remotely possible. Or what about create a virtual device named Modern Family. If you say to Alexa turn on Modern Family will it be able to tell Homeseer that in send text for Kodi plugin.
I'm having trouble creating an event to run a favorite. First off in Kodi local host web viewer I don't see the option for favorite in main menu. I figured how to create a main menu item. However can't figure out the URL for favourites.
Second when creating an event I'm trying to do the following. Player open media, Kodi local host, favourite, than when I select the favorite it shows two tv shows. I select on one and it displays than quickly vanishes and says please select. It's not letting me keep it selected within the event
Any idea with the two issues above. Thanks.
If I have an amazon fire tv. Does Kodi have to be actually on all the time. For example if my amazon tv is on the amazon home menu page will this plugin not work? Confused on how this works. I have both a smart tv and an amazon fire tv. I have a Kodi app on my smart tv. Doesn't seem like this plugin works when Kodi app on tv is not up and running. Wondering how this applies to amazon fire tv as well.
Guest
Hi Spud,
I have a Kodi version 17.5 running on my Qnap NAS.
Now I just installed HS3 with your plugin and I'm getting error...
I troubleshot some and fix few things, got your latest 3.0-1-11, installed package avahi-daemon, make sure all is enabled "Bonjour" on my NAS and all options in Kodi correctly set.
I installed ffmpeg package as well, so it went further...
But now this is the error I have in the logs and I'm stuck here!
Code:Queuing plugin Kodi to load... 05:57:07:7586:[Plug-In]->Finished initializing plug-in Kodi Plugin: Kodi Instance: starting... Connecting to server at 127.0.0.1... Connection attempt #1 05:57:07:9183:[Info]->Plugin Kodi has connected. IP:127.0.0.1:44168 Connected (HomeSeer API 3). Waiting to be initialized... 05:57:08:1145:[Starting Plug-In]->Initializing plugin Kodi ... May-26 17:57:08 INFO Kodi version 3.0.1.11 05:57:08:1196:[Kodi]->INFO Kodi version 3.0.1.11 System.DllNotFoundException: libavahi-client.so.3 at (wrapper managed-to-native) Avahi.Client.avahi_client_new(intptr,Avahi.ClientFlags,Avahi.ClientCallback,intptr,int&) at Avahi.Client..ctor (Avahi.ClientFlags flags) [0x00052] in <fb88040940de4728bee4f76c4c09c2b5>:0 at Avahi.Client..ctor () [0x00000] in <fb88040940de4728bee4f76c4c09c2b5>:0 at Mono.Zeroconf.Providers.Avahi.ZeroconfProvider.Initialize () [0x00001] in <663a8b382afb43c3a47117d32de92186>:0 at Mono.Zeroconf.Providers.ProviderFactory.GetProviders () [0x001f1] in <350cc7bac8c6475198007c91dd299fbc>:0 May-26 17:57:08 ERROR System.Exception: No Zeroconf providers could be found or initialized. Necessary daemon may not be running. at Mono.Zeroconf.Providers.ProviderFactory.GetProviders () [0x00264] in <350cc7bac8c6475198007c91dd299fbc>:0 at Mono.Zeroconf.Providers.ProviderFactory.get_DefaultProvider () [0x0000e] in <350cc7bac8c6475198007c91dd299fbc>:0 at Mono.Zeroconf.Providers.ProviderFactory.get_SelectedProvider () [0x0000f] in <350cc7bac8c6475198007c91dd299fbc>:0 at Mono.Zeroconf.ServiceBrowser..ctor () [0x00008] in <350cc7bac8c6475198007c91dd299fbc>:0 at HSPI_Kodi.KodiPlayerDiscoverer.Start () [0x00000] in <d8af49e330f44a6cb5c26365e2a25706>:0 at HSPI_Kodi.KodiApp.Init () [0x00293] in <d8af49e330f44a6cb5c26365e2a25706>:0 05:57:08:1532:[Kodi]->ERROR System.Exception: No Zeroconf providers could be found or initialized. Necessary daemon may not be running. at Mono.Zeroconf.Providers.ProviderFactory.GetProviders () [0x00264] in <350cc7bac8c6475198007c91dd299fbc>:0 at Mono.Zeroconf.Providers.ProviderFactory.get_DefaultProvider () [0x0000e] in <350cc7bac8c6475198007c91dd299fbc>:0 at Mono.Zeroconf.Providers.ProviderFactory.get_SelectedProvider () [0x0000f] in <350cc7bac8c6475198007c91dd299fbc>:0 at Mono.Zeroconf.ServiceBrowser..ctor () [0x00008] in <350cc7bac8c6475198007c91dd299fbc>:0 at HSPI_Kodi.KodiPlayerDiscoverer.Start () [0x00000] in <d8af49e330f44a6cb5c26365e2a25706>:0 at HSPI_Kodi.KodiApp.Init () [0x00293] in <d8af49e330f44a6cb5c26365e2a25706>:0 Connection lost, exiting Error sending over stream: Unable to write data to the transport connection: Cannot access a disposed object. Object name: 'System.Net.Sockets.Socket'.. 05:57:08:1565:[Info]->Plugin Kodi with instance: has disconnected Disconnected from server - client 05:57:08:1576:[Error]->Initializing plug-in(2): Kodi Instance::Object reference not set to an instance of an objectSTACK: at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.InitIO(string) at Scheduler.clsHSPI.CheckInterfaces () [0x000c4] in <03c63de3f1dc4fe5b4c97ebd223f29dc>:0 05:57:38:3008:[Starting Plug-In]->Initializing plugin Kodi ... Error sending over stream: Unable to write data to the transport connection: The socket has been shut down.
Thanks in advance for help!
Joel
Guest
Spud,
Also here is a screenshot, where the Kodi link is not active and where you don't see it in the manage of plugin.
Joel
Code:sudo apt-get install libavahi-client3
