Missing activities and International characters does not decode propertly
Debug for Get Activities
nov-29 19:10:07 Harmony Hub Plugin: Harmony Hub Test Get Activities output id is PowerOff
nov-29 19:10:07 Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: ----1---PowerOff -
nov-29 19:10:04 Harmony Hub Plugin: Harmony Hub Running Windows version of HarmonyHubControl
nov-29 19:10:04 Harmony Hub Plugin: Harmony Hub OS type is 0
nov-29 19:10:02 Z-Wave Device: Lower Floor Kitchen Island Lights - Momentary power usage Set to 11,6 (W)
nov-29 19:08:37 Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
nov-29 19:08:37 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: 16359735 -
Originally posted by janjoh View Postnov-29 19:43:37 Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
nov-29 19:43:37 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: 16359735 -Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Originally posted by Rien du Pre View PostThe plugin only finds just 1 activity. Can you sent me the .ini file of the plugin and the list of activities you expect ?
cb_debug_checked=1
Hub_Polling_Interval=5
OS version=Windows
Architecture=x86
[Hub1]
cb_hub1_checked=1
[EMAIL=[redacted]
Originally posted by janjoh View PostI have done that several times. The result is always the same.
Go to the <Homeseer> root folder on your system and execute the following command:
bin\Harmonyhub\HArmonyHubControl <logitech userid> <logitech password> <ipaddress of the hub> list_activities
And sent me the outputRegards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Ok this proves there is no problem in the plugin.
Now we have to find out why your activities are not detected.
Can you remove the slash between TV and Netflix in that activity and try again?Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Originally posted by Rien du Pre View PostOk this proves there is no problem in the plugin.
(I am at work, i have removed the slash, but of course i need to trigger a sync of the hub)
