Evetime I restart homeseer the one wire status graphics end defaults back to 150 is there a way to leave it at the set point which I have set to 270 degrees also can you invert the alive output pin?
status graphics end value
What version of the plugin are you running? This is because of the devices being upgraded on startup. I can fix this in a future build.
The alive pin can not be inverted in the plugin but if you know what you are doing then it can be changed in the sketch.
GreigZwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
I will add this to the to do list.
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
This should be fixed in the latest Beta build in the updater.
Scripts = Various
