RFXCOM deleting child devices?
    A couple weeks ago I noticed one of my devices got deleted??
    Jan-24 11:33:28 PM RFXCOM 29 (HSEvent) device:TEMP1[2561]L deleted from the plug-in
    Jan-24 11:33:28 PM RFXCOM 29 (HSEvent) device:TEMP1[2561]T deleted from the plug-in
    Jan-18 11:51:52 PM RFXCOM 29 (CheckTransceivers) transceiver #1 info: resynced
    Jan-18 11:51:52 PM RFXCOM 29 (InitTRX) Connect Transceiver #1 on /dev/ttyUSB0
    Jan-18 11:51:46 PM RFXCOM 29 (InitIO) RFXCOM version is:30.0.0.29
    Jan-18 11:51:40 PM RFXCOM (InitIO) image path =/usr/local/HomeSeer/html/images/RFXCOM/
    Jan-18 11:19:33 PM RFXCOM start shutdown
    So, I recreated it a few days ago. . .then I restarted the RFXCOM plug-in today and it looks like they got deleted again? I did change the batteries. . .does that trigger a device delete (it didn't on the other two devices I changed batteries on today).
    Feb-12 11:17:02 AM RFXCOM 33 (HSEvent) device:TEMP2[1793]L deleted from the plug-in
    Feb-12 11:17:02 AM RFXCOM 33 (HSEvent) device:TEMP2[1793]T deleted from the plug-in
    Feb-12 11:13:08 AM RFXCOM 33 (InitTRX) Connect Transceiver #1 on /dev/ttyUSB0
    Feb-12 11:12:59 AM RFXCOM 33 (InitIO) RFXCOM version is:30.0.0.33
    Why would this device be deleted?
    If you change the battery in a sensor it will get another ID.
    The only thing you have to do is change the ID of one of the logical sensors of the physical sensor (temp, hum or battery) and all ID's are other ID's of the logical sensors are updated by the plug-in.
    Best is to update the ID of battery sensor and enter the battery changed date and expected battery life. The ID's of the temp and hum sensors will be updated automatically.
      But why did the device get deleted in HS too?
        I don't know why the devices are deleted. This not a normal behavior.
        Was the HS system abnormal terminated after a sensor update?
          No restarts during that time that I know of.
