How do I disable voice controls on the ZEE-S2? The goal is to turn all voice processes off and save resources. I am running HS3 ZEE-S2 3.0.0.312 on a Raspi 2.
Voice Control
Voice control does not consume resources unless a command is actually received, and even then uses very little resources in the main HS3 executable. On the Zee it relies on an external application to do the heavy lifting voice recognition that then passes text commands of the what was heard to the Zee. That external application could be Google via Android when you tap the HomeSeer Icon at the bottom of the HSTouch screen on Android devices, via Amazon Alexa service used by Echo or Echo Dot, or by Google Home.
If you still want to disable all voice control, go to the Device Management page, Click the Show All button on the top right of the page to ensure there is no filtering and all Devices are shown, click the check box on the top left of the page to select all Devices, then next to it click the drop down box and select Disable Voice on the bottom of the list, then click OK.
John
