I'm trying to get my first Arduino temp sensor working and have followed Greig's setup guide here:
https://forums.homeseer.com/showthread.php?t=175937
When I connect via com port it works fine and the A0 pin is showing the temp in Homeseer.
I've added a W5100 ethernet shield (I want wired not wireless), I plugged in an ethernet cable and all the lights flash but I can't get it to connect and and can't ping the shield.
Actually, I'm not really sure how to set the IP address.
On line 56 of the Arduino sketch I see an IP address is set. Should I change this line to set the IP for my ethernet shield, does the shield get an IP from my DHCP server or is the IP set some other way?
And should I set the MAC address for my shield too?
Thanks for a great plugin,
Phil
Phil
