For the larger signs, the documented {15reg} and {15fancy} don't seem to work. Instead, in the UI, its {16reg} and {16fancy} and they do work. However, when I use the {16reg} from the pull-down UI, it looks O.K. in the text area, but displays an extra } in the actual sign message.
No biggees, but want to alert you when you do an update.
