A number of my ISY programs were not showing the right "true/false" state in HS, causing events to occur when they weren't supposed to.
I recently replaced my PLM and got into trouble because I hadn't stopped the plug-in. HS went nuts and started running all events with (I presume) ISY devices in their condition one after the other because the scenes and programs were just numbers and perhaps nul or something. I had to restore a backup HS config to fix the problem.
But after fixing it and restarting HS (as well as re-sync'ing the plug-in) several times a number of my ISY programs remained out of sync - presumably to their state at the time the backup config was created. I had to either manually change them in HS or activate the program in ISY for the synchronization to occur.
Is there a way to (ideally) prevent the "crash" that HS experienced and/or have the plug-in double check the state of programs at start up or periodically while it's running?
