Paul, in my devices for egigeozone (in HS) I have some devices that have a status reset and other don't , is there a reason for that?
PHLocation V1 Plug-In [No Longer in Development - See PHLocation2]
Originally posted by sooty View PostNot as the plug-in stands, but if it's going to be a lot of work for you to re-create new devices I could knock together a little script for you that can change them.
If you want me to do that, jut drop me an email and I'll do it this evening.
Paul..
Ok thanks for the offer, much appreciated!!
I've had a little play today, and think I'll need to take a little time thinking how I'm going to do what I want, and test the new plugin again. It might be better to keep the old devices as a backup.
I think I'm going over old ground, followmee is good and works very well. I just think I can get better battery life with the new plugin.
I'll let you know how I get on.
Cheers
J
Originally posted by Rotech View PostI am using egigeozone and lately on my cell the devices gets stuck on a status and can't find a way to change it. Does anyone know how to reset the zone on the cell phone side?
Paul..
Originally posted by Rotech View PostPaul, in my devices for egigeozone (in HS) I have some devices that have a status reset and other don't , is there a reason for that?
If so, then this was something added in a recent version so the fence devices that do not have the buttons were likely created with an older version of the plug-in.
Assuming you don't have any events using them, you can delete the older devices and the next time they are heard they will be recreated with buttons.
Paul..
Originally posted by sooty View PostWhen you say "status reset", do you mean the buttons that allow you to manually set the status?
Paul..Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Hi Paul,
I added a custom user and get the error below
Jan-03 20:51:08 PHLocation Error (CreateDeviceLists) Missing LAT or LON device value for parent ref 315 can't add to custom list!
My config string is -- LAT=213,LONG=214
Ive double checked the IDs and deleted and re-added a few times. Same thing, any ideas??
Cheers
J
Cheers
J
Note "LON" not "LONG"
Paul..
Hello Paul.
Found some cheap hardware for $33, that's GPS & GPRS based. The hardware runs off a simcards text msg or data plan.
http://vandogtraveller.com/cheap-gps...on-and-review/
I have intent on hardwiring on of these into our ca. Is this something that might work with your plugin ?
Many thanks.
Charlie.
Sent from my HTC One max using TapatalkHSPro: 3.0.0.194
PL: Insteon PLM 3.0.5.20,Insteon Thermostat 3.0.1.1 , UltraM1G, RainRelay8, UltraECM3, UltraPioneerAVR3, BLBackup, weatherXML, Jon00 Network & PC Monitor
HW : Win 7 64bit, Intel i7-2600, 16 GB DDR3 Ram, 60 Plus Insteon Dual Band Devices, Rain8 Pro2, Elk M1 Gold, Brueltech GreenEye.
Many thanks.
Charlie.
One of the things I have been working on in recent weeks (really for my own use) is integration of a vehicle tracking unit with the plug-in but the unit I'm working with is designed to report to a server service and costs somewhere in the region of 100 GBP.
Paul..
Check out Section 6.33 of the manual for using internet.
https://www.google.com/url?sa=t&sour...7mDmTemlfZ29VQ
You could wirie this in your car to control door locks and report status of other devices, just like Onstar does. Simple data packages in the US go for $38 a month.
Originally posted by CharlieWayne View PostCheck out Section 6.33 of the manual for using internet.
Paul..
That's cool and I others so appreciate your efforts.
Here's some code from other people trying to do the same thing. You will find a excellent spreadsheet from a drop box download.
I would be willing to donate the cost of the unit if you decide support a device such as this.
EDIT: I forgot the link. -->>. http://stackoverflow.com/questions/2...gt06-tk102-etc
Originally posted by CharlieWayne View PostThat's cool and I others so appreciate your efforts.
Sent from my HTC One max using TapatalkHector
Win.2003 OS, HS3
Considering the cost of only 19 GBP, I've ordered one to play with. Can't promise a time frame on support because I have quite a lot of other things going on at present but I have added it to my to do list.
Paul..
