Folks -
I'm getting periodic errors in my log of the following form:
"12/19/2013 11:31:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero."
These show up in red in the log, and tend to recur every minute or so for a few minutes, then they seem to stop for a while. A log fragment, starting from where they began occurring (bottom of log) after restart, is below.
I have 2 scripts that run every minute, but there is no reference in them to "SetDevTimeSinceChange" - as far as I can tell, this isn't one of my functions.
Is this some sort of internal call that I don't have access to? If so, what am I likely to be calling each minute that might cause this? And why does it start up for a while then stop?
Any advice appreciated,
Jerry
12/20/2013 12:34:26 AM - Device Control - Command sent to Second Floor Cami Bth Sconce: `58 on Dimval: 0 Data: 0
12/20/2013 12:34:25 AM - Device Control - Command sent to Second Floor Cami Bth Sconce: `58 off Dimval: 0 Data: 0
12/20/2013 12:31:25 AM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/20/2013 12:30:25 AM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/20/2013 12:24:29 AM - Turning off light - `65 (Chelsea Bth Ovrh)
12/20/2013 12:24:27 AM - Device Control - Command sent to Second Floor Chelsea Bth Ovrh: `65 off Dimval: 0 Data: 0
12/20/2013 12:24:27 AM - Turning off light - `57 (Chelsea Shower)
12/20/2013 12:24:25 AM - Device Control - Command sent to Second Floor Chelsea Shower: `57 off Dimval: 0 Data: 0
12/20/2013 12:23:31 AM - Flashing light by - `65 (Chelsea Bth Ovrh)
12/20/2013 12:23:29 AM - Device Control - Command sent to Second Floor Chelsea Bth Ovrh: `65 on Dimval: 0 Data: 0
12/20/2013 12:23:28 AM - Device Control - Command sent to Second Floor Chelsea Bth Ovrh: `65 off Dimval: 0 Data: 0
12/20/2013 12:23:28 AM - Flashing light by - `57 (Chelsea Shower)
12/20/2013 12:23:26 AM - Device Control - Command sent to Second Floor Chelsea Shower: `57 on Dimval: 0 Data: 0
12/20/2013 12:23:25 AM - Device Control - Command sent to Second Floor Chelsea Shower: `57 off Dimval: 0 Data: 0
12/20/2013 12:21:27 AM - Turning off light - `69 (Cami Closet)
12/20/2013 12:21:25 AM - Device Control - Command sent to Second Floor Cami Closet: `69 off Dimval: 0 Data: 0
12/20/2013 12:20:28 AM - Flashing light by - `69 (Cami Closet)
12/20/2013 12:20:26 AM - Device Control - Command sent to Second Floor Cami Closet: `69 on Dimval: 0 Data: 0
12/20/2013 12:20:25 AM - Device Control - Command sent to Second Floor Cami Closet: `69 off Dimval: 0 Data: 0
12/20/2013 12:07:25 AM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/20/2013 12:06:25 AM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/20/2013 12:01:25 AM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/20/2013 12:00:25 AM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/20/2013 12:00:01 AM - System - Log file pruning is deleting log file: C:\Program Files\HomeSeer 2\Logs\HomeSeer Log, Closed 2013-11-19 at 2359 58s.log
12/19/2013 11:59:58 PM - System - Switching to a new log file.
12/19/2013 11:59:25 PM - Turn Mot Det Off - Motion detector Lilys bedroom
12/19/2013 11:58:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:57:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:56:25 PM - Turn Mot Det Off - Motion detector Lilys bedroom
12/19/2013 11:55:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:54:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:53:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:52:25 PM - Turn Mot Det Off - Motion detector Lilys bedroom
12/19/2013 11:51:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:50:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:49:25 PM - Turn Mot Det Off - Motion detector Lilys bedroom
12/19/2013 11:48:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:47:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:45:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:44:25 PM - Turn Mot Det Off - Motion detector Lilys bedroom
12/19/2013 11:43:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:42:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:41:25 PM - Turn Mot Det Off - Motion detector Lilys bedroom
12/19/2013 11:40:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:39:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:38:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:37:25 PM - Turn Mot Det Off - Motion detector Lilys bedroom
12/19/2013 11:36:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:35:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:34:25 PM - Turn Mot Det Off - Motion detector Lilys bedroom
12/19/2013 11:33:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:32:59 PM - Device Control - Device: Second Floor Cami Bth Sconce (`58) Dim 100%
12/19/2013 11:32:55 PM - Device Control - Device: Second Floor Cami Bth Sconce (`58) OFF
12/19/2013 11:32:28 PM - Flashing light by - `58 (Cami Bth Sconce)
12/19/2013 11:32:26 PM - Device Control - Command sent to Second Floor Cami Bth Sconce: `58 on Dimval: 0 Data: 0
12/19/2013 11:32:25 PM - Device Control - Command sent to Second Floor Cami Bth Sconce: `58 off Dimval: 0 Data: 0
12/19/2013 11:32:25 PM - Error - In SetDevTimeSinceChange:Length of argument 'String' must be greater than zero.
12/19/2013 11:31:15 PM - X10 Received - N14 (dusk detector Dusk detector - Lilys bedroom) N Off
12/19/2013 11:31:05 PM - X10 Received - M14 (dusk detector Dusk detector - kitchen stairs) M On
12/19/2013 11:31:03 PM - X10 Received - M4 (dusk detector Dusk detector - kitchen sitting area) M On
12/19/2013 11:21:30 PM - X10 Received - O2 (dusk detector Dusk detector - Chelseas bedroom) O On
Jerry
