Attached is the APCSUPSD plug-in for HS2. The APCUPSD allows HS2 to monitor multiple APC UPS devices. Each monitored UPS device must be running apcupsd (http://www.apcupsd.org). The plugin will communicate with apcupsd via a TCP/IP connection. The primary features:
Compatibility
This plugin requires HS2 Version 2.3 or higher.
Version History
Version 1.4.2.2
Attached is the ZIP of the files to install. To install, run the MSI included in the zip file and for new installation only, copy the ini file from the zip file to the config folder in the HS2 installation.
Post any questions, comments, or issues with the APCUPSD plug-in in the discussion thread (here: http://board.homeseer.com/showthread.php?p=1112974 ).
- Monitors local UPS or UPS attached to remote computers
- Monitor up to 5 ups services
- Retrieves UPS information for APCUPSD software which must be running on target computes
- HS2 devices for each monitored UPS
- Event triggers
- Event actions
- Trend chart of power line voltage, load and battery charge
Compatibility
Version History
Version 1.4.2.2
- Initial version posted to Forum
