Rob,
I reported this a few times, the most recent here: https://forums.homeseer.com/showthre...=190269&page=4
Starting a new thread with just this topic. I recently updated to 3.0.2.13 of the plugin and wanted to test this feature to see if previous issues resolved.
According to the zone status graphic in the HS3 web portal the Omni zones should have a value of 0-6, 100, or 101. I track all of these in my HSTouch screens. The only zone options I have in HStouch is to "Bypass" and "Restore". When I bypass though the web portal or through HStouch, the zone value becomes "-1". When I restore it goes back to "0" for secured. The "-1" does not align to the plugin status graphics. If I bypass a zone in snaplink, the snaplink app correctly shows the zone as bypassed, but in HS3 web portal and HStouch is still shows "-1". Similarly when status is not secured and I bypass it goes to -1 when I bypass. I can only test values 0-3. Not sure how to test trouble, tripped, r had trouble. I suspect I'd have to set alarm and trigger a zone to "tripped". I can test this is needed, but seem pretty certain just status 0 and 2 work. 1 and 3 become "-1".
Can you confirm you can replicate this and work on for next release? Since the plugin only has actions to "restore" or "Bypass" could I ask for the ability to "toggle" between the two? This would simplify my hstouch logic/screens.
Guy
Guy
