NOTE: Works on Windows ONLY
This unmanaged plugin uses the built-in charting capabilities on the .NET4 framework to create various charts for Homeseer 3 using device values and other data sources. These charts have a multitude of different settings and parameters; many of which have been exposed for configuration.
The package has the following features:
» Records all values to an independent SQLite database.
» Built in scheduler with several fixed and user definable timers.
» Databases can be automatically or manually updated.
» Charts can be automatically or manually created and updated.
» Chart data sources include device values, global variables and direct reading from ini files.
» Flexible configuration allowing virtually unlimited chart styles & designs.
» Dynamically create charts via a web page with selectable date/times styles etc.
» 2D and 3D designs supported.
» Easily integrated in to HSTouch.
» Once configured, it is designed to be a set & forget application.
» Uses charting built in to .NET 4 framework so no additional charting libraries are required.
As always, it can be downloaded from my site (Click on my banner below). Any issues please post here.
(No Banner seen?- check your Forum Settings - User Settings, Account, Tick 'Show Signature')
