Originally posted by CharlieWayne
View Post
Jon00 Database Charting Utility for Homeseer 3 & Homeseer 4
Originally posted by bdraper View PostThanks Jon. I put a wait of 1 second in between the database and chart build. No change.
Try version 1.0.6 which is now available.
For those who want a secondary Y-axis - I've added that too! Outside automatic operation, you will have to add some additional settings manually as i don't want to overcrowd the initial config - see the end of the docs.
Originally posted by CharlieWayne View PostLooks to be amazing work.
Today were still running HS2 and haven't had a solution to replace mcstemp. From what I see, this is a comparable if not better program.
Are my observations correct?
Than
CharlieBilly
Originally posted by jon00 View PostI've found the bug...Double entry in a routine
Excellent work, on the program. This is a must have for anyone wanting to graph data from multiple sources.Billy
Than
Charlie
Steve
Originally posted by jon00 View PostFor those who want a secondary Y-axis - I've added that too! Outside automatic operation, you will have to add some additional settings manually as i don't want to overcrowd the initial config - see the end of the docs.
I would like to add comments to the INI file, is the ; (semicolon) supported for adding comments to the INI files? I am finding so many uses and there are so many options that I probably need to keep track of some comment information in the INI files just so that I know what I am doing with each chart and table.Billy
Wow, this is impressing. Very nice piece of software. You have tought quite a lot about how to make the charts versitile.
I have one question, is there a way of getting these charts into HSTouch? I thought since the image is in the status of the virtual device, I would be able to show it in HST, but I just get the little icon instead. Is there a way?
Originally posted by Agwan View PostI have one question, is there a way of getting these charts into HSTouch? I thought since the image is in the status of the virtual device, I would be able to show it in HST, but I just get the little icon instead. Is there a way?
http://127.0.0.1:7997/images/jon00/dbchart/chart001.png
If you want the graph to continually update set IsVideo=True and set IsVideoRefreshRate to an appropriate value.
You don't need the virtual devices unless you want to view them in Device Management. The documentation explains how you determine whether virtual devices are created or not for each chart. I found them useful when setting things up but I view all my graphs through HSTouch so did away with all the virtual devices.
You can set the size of the charts generated to suite the size you want the image in HSTouch without worrying how they would look in the status of a virtual device.
Steve
Originally posted by CharlieWayne View PostToday were still running HS2 and haven't had a solution to replace mcstemp. From what I see, this is a comparable if not better program.
Than
Charlie
mcstemp/xapmcsgraphs produce an interactive webpage, with a table of max,min and average values over the period that you are displaying, if you wish to show it.
You can select the period displayed and the end time interactively, this has to be specified in the ini file with Jon00's utility. It's easier to customise the mcs graphs, for instance, you can change the size depending on the IP address of the viewing device, maybe large graphs for a desktop, small ones for a phone.
On the other hand, it's probably easier to generate graphs for displaying elsewhere with this rather than Michael McSharry's utilities.
Jon, I see a difference when starting the EXE manually or letting HomeSeer start it up after a reboot. Just curious if this is by design or if a configuration for the Jon00DBChartingHS3.exe program needs to be created.
FYI: I have the Jon00DBChartingHS3.exe program setup in the HomeSeer startup script to startup automatically.
Symptom:
When I reboot or restart HomeSeer the Jon00DBChartingHS3.exe expects the jon00dbcharting.db3 database to be in the HomeSeer root folder (Example: C:\Program Files\HomeSeer HS3\) and if the database is not then it will create it.
If I decide to exit the Jon00DBChartingHS3.exe process and restart it manually, it expects the jon00dbcharting.db3 database to be in the C:\Program Files\HomeSeer HS3\bin\Jon00DBChart\ folder and if it is not, it will create a blank one.
I found this out after applying one of the latest patches and instead of restarting HomeSeer, I just stopped the plugin by right clicking on the tray icon, updated the files and restarted it by navigating to the file and doublie clicking on it. Obviously this is not a real big issue, now that I figured out what was going on (don't do that no more). LOL.... It gave me a little grief when it happened and I was trying to figure out why my graphs are now empty.Billy
Bdraper,
I can confirm the same. Saw yesterday evening all of the sudden that graphs were not updating anymore. Restarted the utilty adn saw updates happening again. I had visitors so did not give it much thought yet.
Just checked the HS3 installation directory and noticed the db3 file in there. That is where I realised having the same issue as you just described.
Wim-- Wim
WimBilly
