Jon00, I have to say you are ruining my holiday plans! HAHAHA!!! I am spending waaayyy t0o much time playing with these charts, and loving it!!
One issue I can't seem to resolve, how come my charts are coming up with various widths? Some are wider than others. I can't seem to figure out how to get the charts to use the entire width of the border as in the examples below.
Again, thank you! This makes my HS system so much more powerful.
On a side note, what do you think about having the ability to pre-process device values before they are entered in the database? For example, on my Wine Cellar chart below, I ended up creating a virtual device that divides the actual wattage by half and using that virtual device in the chart instead of the actual value. Because the wattage is so much higher than the temperatures, I wanted to show more of the temperature range than the wattage.
MCSTemperature was what I used in HS2, and it allowed for multiple scales in the vertical plane. I realize this likely isn't possible, so I thought a scaling factor for a particular device would be a solution.
