Originally posted by jon00
View Post
Jon00 Database Charting Utility for Homeseer 3 & Homeseer 4
Originally posted by jon00 View PostClick on the Name link for the device in the device management page. What is shown for the code and address fields?
Weird how the values for the WeatherXML are different. Sorry for the confusion.
On the Technology Address field (Advanced tab) the value is:
Location 1 HST Temperature
On the Address field (Configuration tab) the value is:
Notice how the Technology Address field has only one space between Location 1 and HST Temperature and the Address field has 2 spaces. Strange but I got it figured out.
Thanks again.Billy
V1.0.3 Now Available
Version 1.0.3 is now available.
Changes from V1.0.2
Added TitleColor setting in Jon00DBChartingStyle.ini
Added Markerstep setting in Jon00DBChartingStyle.ini
Added DataXMultiplier setting to Database configuration (Jon00DBCharting.ini)
Added new methods to obtain data from Homeseer devices
Added replacement tags to labels
Moved AxisYMaximum setting from Jon00ChartingStyle.ini to Jon00ChartingCreate.ini
Added auto function to BaseLineValue and AxisYMaximum setting
I have not provided an updater for those using previous versions so you will need to add the entries in blue manually.
Also note the text in bold:
If you used the undocumented Multiplier1....Multiplier10 function to change the data values, this is now renamed to Data1Multiplier...Data10Multiplier, however the existing settings should still work. Please update and delete all the old Multiplier settings.
Finally, I have moved AxisYMaximum from Jon00ChartingStyle.ini to Jon00ChartingCreate.ini as it was incorrectly located in V1.0.2
Have fun!
Originally posted by jon00 View PostIf you used the undocumented Multiplier1....Multiplier10 function to change the data values, this is now renamed to Data1Multiplier...Data10Multiplier, however the existing settings should still work. Please update and delete all the old Multiplier settings.
Steve
Originally posted by jon00 View PostMoved AxisYMaximum setting from Jon00ChartingStyle.ini to Jon00ChartingCreate.ini
I have set BaseLineValue=auto on a couple of charts but they are still showing with the baseline at 0. Ones that I have set a specific baseline value for still work OK.
All my charts are using AxisYMaximum=auto. Previously the charts would draw with the maximum almost exactly set to the maximum data value. In otherwords somewhere on the chart a data value would reach the top of the chart. Now all the charts have some leeway at the top, i.e. the maximum of the YAxis is quite a bit higher than the maximum data value. For example a chart showing values from all my internal temperature sensors is showing with a YAxis max of 30 when the highest data value is only 22. I much preferred how it looked previously.
Steve
Steve,
Under the respective [DBTableX] Add:
AutoAdjust=0
Then try:
AutoAdjust=0.05
Is it any better for you. I do round up to the nearest 10 as the Y-scale was getting strange increments.
Other people were complaining that there was no leeway at the top so I cannot win!
The setting internally is set to 0.1
AutoAdjust=0
Then try:
AutoAdjust=0.05
I can fully understand the impossibility of pleasing everybody.
Any thoughts on the BaselineValue=auto, I still can't get that to work on my charts?
Steve
Jon,
I had deleted all before updating and started from the beginning.
There are no devices created ( and no graphing ) .
The HS3 log shows :
Dez-27 18:25:52 Jon00_DBChart Ready
Dez-27 18:25:52 Jon00_DBChart Version 1.0.3.1
Dez-27 18:25:52 Jon00_DBChart Connected to Homeseer
I don't know what's going wrong !
Fischi
Originally posted by jon00 View PostWhat is the lowest value being displayed on the chart?
1 chart has lowest data value approx 7 highest approx 22. Chart YAxis goes from 0 to 30. Interestingly the AutoAdjust=0 with AxisYMaximum=auto doesn't seem to be working on that one although it does on my other charts.
Steve
