Originally posted by SteveMSJ
View Post
Jon00 Database Charting Utility for Homeseer 3 & Homeseer 4
I've released V1.0.4 which is now available.
Changes since 1.0.3:
Fixed new DataXMultiplier setting.
Fixed auto function to BaseLineValue and AxisYMaximum with negative numbers.
Added AxisXIntervalType setting in Jon00DBChartingStyle.ini
Added LegendColor setting in Jon00DBChartingStyle.ini
Added $counter: , $timers: , $timerm: , $timerh: & $timerd: as methods to add data to the database.
Added [devicevalue1000], [devicevalue100] and [devicevalue10] replacement variable tags.
I'll admit it is not 100% tested but I wanted to get it out now as I may not be around for a period of time.
Hi Jon,
I tried to use the Markerstep function. It skips adding the data point marks as configured, but still adds the numerical values of every step. I guess I thought the Markerstep and ShowValues were tied together, they are not. Can we do the same step option with the numeric value displays?
(latest 1.0.5 build)Mike
Jon, when I use the manual update of the database there are two (2) rows being inserted into the database for each run. The modification to the data multiplier for rounding works great.
I am using [DBTable3] and the timer entry is blank. Attached are a few screenshots of the event and database before and after running the event once. Any ideas?Billy
Originally posted by bdraper View PostJon, when I use the manual update of the database there are two (2) rows being inserted into the database for each run. The modification to the data multiplier for rounding works great.
Looks to be amazing work.
Today were still running HS2 and haven't had a solution to replace mcstemp. From what I see, this is a comparable if not better program.
Are my observations correct?
Than
CharlieHSPro: 3.0.0.194
PL: Insteon PLM 3.0.5.20,Insteon Thermostat 3.0.1.1 , UltraM1G, RainRelay8, UltraECM3, UltraPioneerAVR3, BLBackup, weatherXML, Jon00 Network & PC Monitor
HW : Win 7 64bit, Intel i7-2600, 16 GB DDR3 Ram, 60 Plus Insteon Dual Band Devices, Rain8 Pro2, Elk M1 Gold, Brueltech GreenEye.
