Pentair and Homeseer
    Originally posted by thetaz01 View Post
    Hey Clafa,
    so I finally got all the pieces to fall into place..
    Took me a little bit,
    So I have the Autelis controller hooked up on the network, and I can control my pump, and see RPM, and Watts...
    I added it into the plugin in homeseer,
    I have a TON of devices created...
    one thing that confuses me, under pump #1, on the Autelis control page, I have a drop down with Program number I can run, my program 1 is scheduled on the pump to run at night, I can drop down to program 1, and turn on the pump whenever I want..
    I do not see anything on the homeseer created devices with a drop down that is similar
    also, when I goto the Autelis page, and turn on the pump, to program 1, I see the status of RPM, and watts, in real time, I check the devices in homeseer that list Pump 1 RPM, and PUmp 1 Watts, and the numbers don't update
    any help would be awesome, thanks so much
    what is the exact model of your Autelis controller?
    have you set the interface type to Pentair from the config page?
    could you post a screenshot of the devices that have been created?
    any error in the logs?
    could you set the log level to debug and post what you get when the plugin is restarted.
    ALSO SIDE NOTE for the creator of this plug in IF he reads this...
    I installed the plug in two weeks or so ago, not realizing the devices were going to take me so long to get, and connect.. I only have 9 days left, any chances, I can get an extension to make sure I can get what I need.. working?
    thanks
    fred
    I don't have any control over licensing, but you can ask HST to give you another trial license for this plugin.
      Controller is an Autelis Intelliflo controller XN200
      I went to the setup page, for pump details, pump type is VF
      Log on debug mode
      Jun-19 5:30:03 PM Autelis DEBUG WebException: Timeout The operation has timed out
      Jun-19 5:30:01 PM Autelis DEBUG WebException: Timeout The operation has timed out
      Jun-19 5:30:01 PM Autelis INFO CMD SENT: http://10.0.0.59:80/chem.xml?
      Jun-19 5:29:59 PM Autelis ERROR WebException: Timeout The operation has timed out
      Jun-19 5:29:59 PM Autelis INFO CMD SENT: http://10.0.0.59:80/pumps.xml?
      Jun-19 5:29:57 PM Autelis DEBUG WebException: Timeout The operation has timed out
      Jun-19 5:29:57 PM Autelis INFO CMD SENT: http://10.0.0.59:80/status.xml?
      Jun-19 5:29:55 PM Autelis INFO CMD SENT: http://10.0.0.59:80/names.xml?
      Jun-19 5:29:55 PM Autelis INFO Autelis version 3.0.0.22
        looks like the plugin can't access the autelis controller.
        make sure the ip is correct and that it is accessible from your HS3 machine. You can test for example from a browser this url: http://10.0.0.59:80/pumps.xml?, it should return some xml describing the pumps state.
          Hey Hey, ok I finally resolved my connectivity issue..
          I have perfect connctiviety now..
          I see constant updates on the RPM, and Watts when on.,
          I still do have the problem of, In the web portal I see a drop down for the pump for Programs 1-4
          And I can select a program to run, to start up the pump..
          I DO not see a correlating action on the dozens of devices created in homeseer
          thanks
          Fred
            thanks
            Fred
            I guess I need to adapt the plugin a bit for Pentair Intelliflo controllers, because they seem to work a bit differently from the other Pentair controllers. I guess a lot of the devices created in HS are useless for you.
            Can you post the xml you get (if any) when you paste the following urls in a browser (change the ip address if needed)
            thanks
              #21
              <?xml version="1.0"?>
              -<response>
              -<system>
              <runstate>50</runstate>
              <model>0</model>
              <haddr>0</haddr>
              <opmode>0</opmode>
              <freeze>0</freeze>
              <sensor1>0</sensor1>
              <sensor2>0</sensor2>
              <sensor3>0</sensor3>
              <sensor4>0</sensor4>
              <sensor5>0</sensor5>
              <version>1.1.3</version>
              <time>1530663656</time>
              </system>
              -<equipment>
              <circuit1>0</circuit1>
              <circuit2>0</circuit2>
              <circuit3/>
              <circuit4/>
              <circuit5/>
              <circuit6/>
              <circuit7/>
              <circuit8/>
              <circuit9/>
              <circuit10/>
              <circuit11/>
              <circuit12/>
              <circuit13/>
              <circuit14/>
              <circuit15/>
              <circuit16/>
              <circuit17/>
              <circuit18/>
              <circuit19/>
              <circuit20/>
              <feature1>0</feature1>
              <feature2>0</feature2>
              <feature3>0</feature3>
              <feature4>0</feature4>
              <feature5>0</feature5>
              <feature6>0</feature6>
              <feature7>0</feature7>
              <feature8>0</feature8>
              <feature9>0</feature9>
              <feature10>0</feature10>
              </equipment>
              -<temp>
              <poolht>0</poolht>
              <spaht>0</spaht>
              <htstatus>0</htstatus>
              <poolsp>0</poolsp>
              <spasp>0</spasp>
              <maxplsp/>
              <pooltemp>0</pooltemp>
              <spatemp>0</spatemp>
              <airtemp>0</airtemp>
              <soltemp/>
              <tempunits>F</tempunits>
              <htpump>0</htpump>
              </temp>
              </response>
              not page found
              -<response>
              -<chlor>
              <chloren>0</chloren>
              <poolsp/>
              <salt/>
              <chlorerr/>
              <chlorname/>
              </chlor>
              </response>
              -<response>
              -<pumps>
              <pump1>699,2250,0,0,0</pump1>
              <pump2/>
              <pump3/>
              <pump4/>
              </pumps>
              <prog>0,0,0,0</prog>
              </response>
              thanks
              Yeah a TON of created devices that I believe don't even exist on my controller..
              See above I have pasted your request..
              also be aware, on the pump status, I copied and pasted when my pump was in fact on
                #22
                Hello, just curious if you had any time to tweak the plug in for the controller I am using..
                I have not purchased, but finally have the controller working solidly, and just need to now get it in homeseer.. BUT don't want to introduce all those devices, if you are working on tweaking it..
                thanks
                Fred
                  #23
                  thanks
                  Fred
                  I'm on vacation right now , so I probably won't be able to do that before August. Sorry.
                    #24
                    Hey.. ahh LOL ok, that's a great reason !
                    have a great vacation..
                    I can wait for it.. Ill use the controller manually for now
                    thanks so much
                    I don't close my pool till September sometime.. so im more then happy to help you test when you do start tweaking for it..
                    let me know
                    thanks
                    Fred
                      #25
                      thanks so much
                      let me know
                      thanks
                      Fred
                      Having the superfluous devices isn't that big a deal. They appear on my system and I just ignore them.
                        #26
                        Agreed, however, all I can do is monitor, I have no way to trigger any program..
                        So its not really worthwhile for me right now, until I can also control it...
                        Fred
                          #27
                          in version 3.0.0.23 available here, I have added specific support for Pentair Intelliflo.
                          From the config page set the Type field to "Pentair Intelliflo", then manually delete all your Autelis devices. Then restart the plugin.
                          Using the xml you posted above, here is the only devices that are created:
                          Click image for larger version  Name:	intelliflo.png Views:	1 Size:	61.2 KB ID:	1242301
                            #28
                            thanks
                            Fred
                            Glad to hear it, Fred. Hopefully this will also work for others.
                            ______________________________
                            Alexandra
                            pool sheds from Summerwood
                              #29
                              spud Im finally getting time to install this, however the link you have in the post from aug 20th, where you say you have version 3.0.0.23 available "HERE" doesn't work
                              id like to test, please let me know how I can get it to test,
                              thanks
                              fred
                                #30
                                thanks
                                fred
                                here is the correct link: https://forums.homeseer.com/forum/po...n-beta-testing
