I'm using an IRLinc to control keypad buttons (A,B,C,D). Each btn controls a group. The sticky on keypad programming was very helpful. I found a diagram of the problem (see below), LED lights on button, but no groups are fired. I didn't see a solution on how to trigger the group from the keypad.
Need help with Keypadlinc
controlling a kpl button remotely will NOT trigger the group/scene that is controlled by the kpl btn. this is not part of the insteon protocol.
Create a group in the plugin with a controller (maybe the irlinc btn) and include the kpl btn as a responderMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postcontrolling a kpl button remotely will NOT trigger the group/scene that is controlled by the kpl btn. this is not part of the insteon protocol.
if I want the keypad to have radio button behavior I assume I'll have to implement that in event(s) or will the plug-in radio btn functionality still work when the irLinc triggers the keypad btn? Note: I am cross linking the KP and IR btns (I assume that is the right thing to do).
Originally posted by krh1009 View PostOK...thanks.
if I want the keypad to have radio button behavior I assume I'll have to implement that in event(s) or will the plug-in radio btn functionality still work when the irLinc triggers the keypad btn? Note: I am cross linking the KP and IR btns (I assume that is the right thing to do).Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postthe plugin does support programming radion buttons, and should continue to keep them in sync when used with groups. let me know how it goes
The irLinc turns on group A and lites KP btn A. Next when irLinc turns on group B and KP B lites BUT btn A stays on.
I did add an event: when A lites then turn off B, C, D. I need to add 3 more to complete radio feature.
Note: plugin radio support works for manual/finger press of KP btns, just not as a responder. Screen shot of radio config attached,...is it correct?
what plugin version are you running? i made changes to thus in the beta versionMark
HS3 Pro 4.2.19.5
