HomeSeer Mobile Beta 0.0.1
Requests/Issues
Minor issues and requests:
If you need to move an icon/device/event button the other buttons don't move out of the way (like Android does) You need to manually shift the other icons out of the way.
When you create a new button it will overlap one of the existing buttons at times.
Any way to rearrange the order of the dashboards? Right now they are as created. If you create a new dashboard, it's all the way to the right. It would be nice to sort them later as the user creates new dashboards.
Would be nice to be able to swipe anywhere on the main screen to have it switch dashboards? (like in Android home screen to side screens.
Overall, I'm really digging the new app!
I've been creating and editing for the last 5 hours or so.Dan-O
HomeSeer contributor since summer 1999, yes 1999!
Device list /dashboard issues
Sent some feedback in app.
Android 8.0.0 Oreo Moto Z play Droid w/hometroller SEL pro.
Not a problem free beta but promising. I didn't find any core functionality missing
Bugs
*I can only add one device to a dashboard at a time before it throws error "error loading" in device list. Message goes away if I delete a dashboard or if I visit dashboard after adding each device.
*device list has duplicate entries in room filter
*Dashboard widget editor
-- group & room reversed (i.e. "living room" was a group and "outlet" was a room)
-- Disabling "room"OR "group" check box has no affect on display but if both unchecked, both disappear from widget
Weird/bad UI
*Events on dashboard have a "run event" confirmation but device controls do not. Dashboard should have consistent behavior across widgets.
*No scroll bars to indicate relative position. Or even that scrolling is possible.
Good:
*App works via myhs & ip
*Events and devices work on dashboard and in appropriate menu (when there aren't errors)
*Resizing works on dashboard.
*I like the "primary device" functionality and being able to disable secondary functions and hide rooms/groups.
Want to see:
*Way to export/share a dashboard layout.
*Night mode/dark themeLast edited by Kigmatzomat; July 13, 2018, 11:43 PM.
Guest
Originally posted by actibus View PostNot available in Norway?
Play store says it can't find it even with the linkHSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Here are my first observations. Most issues have been reported already in this thread:
- Cannot download from the playstore and the link provided produces a "not found" error. Using a US proxy enables me to see the app in the store, but still unable to download. I had to use apkpure to download the apk and install.
- Unable to login using MyHS. First time the app crashed, subsequent tries simply return me to the login screen without any error
- After logging in by IP, I cannot see any devices. "Error while loading devices"
- Event groups seem to be in random order. Events are being sorted alphabetically.
I'll try again on the next versionstefxx
Setup fine on a Samsung S8.
I can see devices and events but only one camera.
The one I can see is Foscam, the others are Hikvision. I have them set up in HSTouch and can view them through the HSTouch mobile app but not this new app.
Edit: some progress!
For HSTouch I have the url in snapshot.
I added the same url to MJPEG and it flashes up in the new app, then goes off and it doesn't show in the HSTouch app!Last edited by IanIreland; July 14, 2018, 09:44 AM.
Check all you devices and make sure all of them are assigned a floor and a room. I see a blank button in the screen shot, maybe you have some blank locations? Should not be a problem but maybe its something we have not tested for yet.
Originally posted by mrhappy View PostHmm...I can't display any devices at all, events and anything else seems to work OK but I just get an error with no additional detail nor any ability to report it.
I am running it on a Xiaomi Redmi Note 5, can't help much more than posting a screenshot unfortunately.
